Troubled with Instant Ints and TMR2
Results 1 to 28 of 28
    May 2006
    Del Rio, TX, USA
    ...is there a way to point to each Bit of this array?
    Melanie has provided the answer. See 3. How can I reference a BIT in a BYTE ARRAY? in her very helpful Bits, Bytes Words and Arrays Post.
    Thanks again Melanie.
    SteveB
    Default Thanks for that link Steve
    Thanks Steve i will be using it.
    On the other hand.
    Darrel this link
    http://www.picbasic.co.uk/forum/show...php?t=3891#LAB ...
    Its the post about the EXT modifier, i have been using it as a label to create tables in codespace in the past, BUT: right now i am using 628A wich doesn´t support READCODE instruction, can i still use it to create a table in codespace? if so (i guess i can) how can i read it?. It is a 14 bits x 120 Word, since the device is 14 bit i guess i could store each word in a memory space? kind of like the code to store strings in codespace? I havent been able to use the last one since i dont know how the data would be stored as Words and not as strings. Again ignorant about asm.
    This is my table
    </i></font><b>ASM
    </b><font color="#008000">DataTable
        DW 11111111111111b
        DW 01010111111111b
        DW 00000101010101b
        DW 00000001010101b
        DW 10101000000101b
        DW 11111000000000b
        DW 01111110000000b
        DW 01011110101000b
        DW 00000111101010b
        DW 10000011111010b
        DW 11100001111110b
        DW 11111001011111b
        DW 01111000010111b
        DW 00011100010111b
        DW 10000110000101b
        DW 10000110000001b
        DW 11100010100001b
        DW 01110011100000b
        DW 00111011111000b
        DW 00011101111000b
        DW 10001101111110b
        DW 11000100011110b
        DW 11100100011111b
        DW 01110010000111b
        DW 00111010000111b
        DW 10011011100001b
        DW 10001111100001b
        DW 11001101100001b
        DW 01100101111000b
        DW 00110000111000b
        DW 00110000011000b
        DW 10011010011110b
        DW 11001010001110b
        DW 01001110000110b
        DW 01100111000111b
        DW 00110111100111b
        DW 10110001100011b
        DW 11010001110001b
        DW 11001000111001b
        DW 01001100011001b
        DW 00101110011000b
        DW 10110110011100b
        DW 10110111001100b
        DW 11010011001110b
        DW 01001001100110b
        DW 01001001100111b
        DW 00101100110011b
        DW 10110100110011b
        DW 11110110110001b
        DW 11010010011001b
        DW 01000010011001b
        DW 00001011001100b
        DW 10101111001100b
        DW 10111101101100b
        DW 11110101100110b
        DW 01010100100110b
        DW 00000000110110b
        DW 00001010110011b
        DW 10101010010011b
        DW 11111111011011b
        DW 01111111011001b
        DW 01010101001001b
        DW 00000001001101b
        DW 10000000101100b
        DW 11101000100100b
        DW 11111010110110b
        DW 01111110110110b
        DW 00010110110010b
        DW 00000111010011b
        DW 10000011010011b
        DW 11100001001011b
        DW 01111001001001b
        DW 01111100101101b
        DW 00011100101101b
        DW 10000110101100b
        DW 11000110110100b
        DW 11100011110100b
        DW 01111011010010b
        DW 00111001010010b
        DW 10011101000010b
        DW 10001100001011b
        DW 11000100001011b
        DW 01100010101011b
        DW 00110010101101b
        DW 00111010111101b
        DW 10011011110101b
        DW 11001111010100b
        DW 11000101010100b
        DW 01100101010010b
        DW 00110000000010b
        DW 10111000001010b
        DW 10011010101011b
        DW 11001110101011b
        DW 01001111111111b
        DW 00100111111101b
        DW 00110001111101b
        DW 10110001010101b
        DW 11011000010100b
        DW 01001000000000b
        DW 01001110000000b
        DW 00100110100010b
        DW 10110110101010b
        DW 11110011101010b
        DW 11010011111111b
        DW 01001001111111b
        DW 00001101011111b
        DW 10101100010101b
        DW 10110100000101b
        DW 11110110000101b
        DW 01010010000000b
        DW 01001011100000b
        DW 00001011101010b
        DW 10101101111010b
        DW 11111101111010b
        DW 11110100111111b
        DW 01010000011111b
        DW 00000010010111b
        DW 10001010000101b
        DW 10101010000101b
        DW 11111111100001b
    </font><b>ENDASM
    There's still the 128 Byte EEPROM on board option... but it's way too limited.
    LOOKUP(2)?
    External EEPROM?
    Default Hi! Thanks Eproom for other stuff
    Eproom will store the strings of my LCD, and i would need 256 Bytes to store this table in Eproom vs the posible 120 "SemiWords" of codeSpace.
    Thanks for your concern
    And.. no external component.. i am looking for a low budget device here, also low Real State.
