Troubled with Instant Ints and TMR2
Results 1 to 28 of 28
    Unhappy Thanks for your replies
    Joe S.
    Modifications...
    i have a DT for 628A since it needs bank modification from 877A.
    In the second one i am modifing Elapsed to interrupt every 125us it is not meant for timing but for interrupting. All i did was modifing the timerconst to be $FFA7 in the case of 4Mhz Osc. I am not using this anyway you can see the TMR1 interrupt is not defined for elapsed interrupt, only TMR2.
    mister_e
    If i get this right, and from the datasheet the timer2 interrupts when Tmr2 reaches PR2 value, tmr2 "should" go to 0 after this, BUT it seemed not TO i had to turn TMR2= 0 in the interrupt routine, Otherwise i was getting weird interruptions (watched it on my osciloscope)
    Still cant get my 125us interrupt with 4Mhz internal OSC this should be possible unless DT´s routines take more than 125 instructions to work (just my guess),.. Patience....Again i am sure HE knows
    oups... missed the Elapsed timer... i'll read the according posts/thread about it as i never used it.
    Sorry
    Lightbulb I just doesnt work.. Impossible?
    Ok i figured out a way to measure my interrupts.
    The interrupt routine simply Toggles a pin of the micro on each interrupt and i measure such pin with my oscilloscope. The frequency of sampling is wrong.
    Problems:
    1. The TMR2 doesnt just go back to 0 after reaching PR2 value.. i had to set it to 0 otherwise i get unwanted interrupts.
    2. I cant believe this to be impossible so i made a small RX int.... when i press "1" PR increases by one.. else it goes down one, so i can sweep controlling by my keyboard. RESULT: No No it doesnt work.... i never get to my 125us interrupt it suddenly jumps back to the lower frequency after a point.
    Is 125us to much to ask for 4Mhz.. teorically i would say No.. 125 instructions are a lot of instructions... and i am only sampling at this point of my software so: what could be the problem?
    I cant use other OSC since i am using internal OSC and A7 pin for other purpouses... Since i am only sampling would something like pauseuS 125 : sample work?... What should be the timing consideration in this case?
    i still need someting like:
    Sample:
        pauseus 125
        Samples [NumSamples] = CMCON.7
        NumSamples = NumSamples + 1
        IF NumSamples = 120 THEN return
        goto Sample
    How many instructions take this sub to work? i guess i have to take them into account for my timing to be correct!!!
    Thanks on any help.. Interrupt 125uS 4Mhz still in need!!
    mmm, can you (or someone else) try the following for me? Try both with a 4 MHz and then with a 20MHz crystal. You just need to change the DEFINE OSC and the code will automatically change for you (config fuses, Prescaller and PR2). Sit a scope on PinActivar (PORTB.0) and measure the frequency. It has to be close of 4KHz
    Code 1 with ON INTERRUPT
            DEFINE OSC 4   ' select 4 or 20
            PinActivar      VAR portb.0
            LoopCount  VAR WORD
            TMR2IF VAR PIR1.1
            TRISB = 0
            portb = 0
            INTCON  = %11000000
            PIE1    = %00000010
            PIR1    = %00000000
            OPTION_REG = %00000000
            PinActivar = 0
    @   IF (OSC==20)
    @       __config _HS_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
            pr2 = 155
            T2CON = %00000101   ' TMR2 Prescale 1:4
    @       ELSE
    @       __config _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
            PR2 = 118
            T2CON = %00000100 ' TMR2 prescale 1:1
    @       ENDIF
            ON INTERRUPT GOTO Sample
    MAIN:
            GOTO MAIN
    disable
    Sample:
            TOGGLE PinActivar
            tmr2if=0
    resume
    enable
    Code 2, with DT-INT
            INCLUDE "c:\pbp_prog\Include_routines\DT_INTS-14.bas"
            INCLUDE "c:\pbp_prog\Include_routines\ReEnterPBP.bas"
    INT_LIST  macro    ; IntSource,    Label,  Type, ResetFlag?
            INT_Handler   TMR2_INT,  _Sample,   PBP,  YES
        INT_CREATE
            TRISB = 0
            portb = 0
    @   IF (OSC==20)
            pr2 = 155           ' load tmr2 PR2 to reset every 125 uSec
    @       ELSE
            PR2 = 118
    @       ENDIF
    @       INT_ENABLE  TMR2_INT
    MAIN:
            GOTO MAIN
    Sample:
            toggle pinactivar
    @ INT_RETURN
    i'm curious to knwo if there's any significant difference between the above, and how much. I feel them equal @20MHz, but some doubt on 4MHz.
    Obviously this code don't do anything interesting... i'm just curious...
    As i said, i can't check anything it here.
    Default Maybe this would work better tha Instant Interrupts here!
            LoopCount  VAR WORD
            TMR2IF VAR PIR1.1
            TRISB = 0
            portb = 0
            INTCON  = %11000000
            PIE1    = %00000010
            PIR1    = %00000000
            PinActivar = 0
    @   IF (OSC==20)
            pr2 = 155
    @       ELSE
            PR2 = 118
    @       ENDIF
    MAIN:
            GOTO MAIN
    disable
    Sample:
            TOGGLE PinActivar
            tmr2if=0
    resume
    enable
    Mister_E i am going to test with the ON INTERRUPT way because it might work better here, i am not doing much code between Samples so this could work fine. Thanks for the idea...
    The DT option as you can read at Darrels link will not work either.
    Quote Originally Posted by Josuetas View Post
    This page might explain it.
    http://darreltaylor.com/DT_INTS-14/kudos.html
    Especially the last paragraph.
    Red face Ok now thats bad news
    So Darrel if i made this with just an ASM interrupt i would be able to get my 125uS since i wouldnt need the Reenter Context Saving...
    BUT please o please can you help me?..
    I use to get to this point where: i dont know any assembler!!!
    even worst
    A bit Array of 120 samples in Assembler .... mmm..... mmmmm....
    By the way would you consider (in my case) the pauseus 125 Take Sample option?
    Please some lead to solve this matter.
    Thanks again
    DJC
    Correct.
    In ASM, you would just shift the bits into a byte var. After 8 bit's move to the next byte. After 15 bytes you're done.
    YES!
    Your program just sits in a loop anyways, waiting for the sample to finish.
    No need to use interrupts, if it's not doing anything in the first place.
    Or, you can still use the timer. Just poll the TMR2IF Flag.
    Default Thanks for your advise Darrel
    I will keep working on the interrupt option... This is supposed to detect DTMF (we talk about it before) so for it to work in the background of anything else is the best choice.
    Everything is so complicated in ASM!.. thanks god there is picbasic.
    Here's a quick untested stab at an ASM handler.
    Change the Handler type to ASM
    Samples      VAR BYTE[15] BANK0 SYSTEM
    SamplePTR    VAR BYTE     BANK0 SYSTEM
    SamplesAddr  CON EXT
    @SamplesAddr = Samples
    BitCount     VAR BYTE     BANK0 SYSTEM
    ByteCount    VAR BYTE     BANK0 SYSTEM
    FlagSample   VAR BIT
    TMR2ON       VAR T2CON.2
    ;----[Start getting the 120 samples]------------------------------------------
    GetSamples:
        FlagSample = 0
        SamplePTR = SamplesAddr
        ByteCount = 15
        BitCount  = 8
        PR2 = 125 : TMR2 = 0 : TMR2ON = 1
    ;----[TMR2 Handler]-----------------------------------------------------------
    Sample
        MOVE?BB  SamplePTR, FSR      ; Load FSR with pointer to array
        MOVE?TT  CMCON,7, STATUS,C   ; Put sample in carry flag
        rrf      INDF, F             ; Shift in the sample bit
        decfsz   BitCount, F         ; Are all 8 bits in ?
        goto     Int_Done            ;   NO, done for now
        MOVE?CB  8, BitCount         ;   Yes, reset bitcount
        incf     SamplePTR, F        ;     Point to next byte
        decfsz   ByteCount, F        ; Are all 15 bytes done ?
        MOVE?CT  1, _FlagSample      ;   Yes, Indicate - Samples Complete
        MOVE?CT  0, _TMR2ON          ; stop the timer
    Int_Done
        INT_RETURN
    Smile I Will be testing it for the next couple of hours
    Your wish to help is INFITE and appreciated Darrel.
    Thanks Again
