Here's a quick untested stab at an ASM handler.
Change the Handler type to ASM
Code:Samples VAR BYTE[15] BANK0 SYSTEM SamplePTR VAR BYTE BANK0 SYSTEM SamplesAddr CON EXT @SamplesAddr = Samples BitCount VAR BYTE BANK0 SYSTEM ByteCount VAR BYTE BANK0 SYSTEM FlagSample VAR BIT TMR2ON VAR T2CON.2 ;----[Start getting the 120 samples]------------------------------------------ GetSamples: FlagSample = 0 SamplePTR = SamplesAddr ByteCount = 15 BitCount = 8 PR2 = 125 : TMR2 = 0 : TMR2ON = 1 return ;----[TMR2 Handler]----------------------------------------------------------- ASM Sample MOVE?BB SamplePTR, FSR ; Load FSR with pointer to array MOVE?TT CMCON,7, STATUS,C ; Put sample in carry flag rrf INDF, F ; Shift in the sample bit decfsz BitCount, F ; Are all 8 bits in ? goto Int_Done ; NO, done for now MOVE?CB 8, BitCount ; Yes, reset bitcount incf SamplePTR, F ; Point to next byte decfsz ByteCount, F ; Are all 15 bytes done ? goto Int_Done ; NO, done for now MOVE?CT 1, _FlagSample ; Yes, Indicate - Samples Complete MOVE?CT 0, _TMR2ON ; stop the timer Int_Done INT_RETURN ENDASM
