Joe S.
Modifications...
i have a DT for 628A since it needs bank modification from 877A.
In the second one i am modifing Elapsed to interrupt every 125us it is not meant for timing but for interrupting. All i did was modifing the timerconst to be $FFA7 in the case of 4Mhz Osc. I am not using this anyway you can see the TMR1 interrupt is not defined for elapsed interrupt, only TMR2.
mister_e
If i get this right, and from the datasheet the timer2 interrupts when Tmr2 reaches PR2 value, tmr2 "should" go to 0 after this, BUT it seemed not TO i had to turn TMR2= 0 in the interrupt routine, Otherwise i was getting weird interruptions (watched it on my osciloscope)
Still cant get my 125us interrupt with 4Mhz internal OSC this should be possible unless DT´s routines take more than 125 instructions to work (just my guess),.. Patience....Again i am sure HE knows![]()
