Read & Send SMS from a Mobile using PIC Microcontroller
Results 1 to 19 of 19
    May 2008
    Italy
    abbas.khodaeian, I am sorry but you cannot reach an acceptable boudrate of 115200 with 16F series even with a 20 Mhz oscillator.
    If you want to use the 16F84a, then you must change the phone type and use a brand with boudrate @ 9600 (siemens for instance. make sure they work in text mode)
    i don't need the high frequency for processing, but i need high baud rate to communicate with the nokia 3310
    The high frequency clock and the pic 18F are necessary to reach the high boudrate required by your nokia 3310.
    Al.
    mostly right, but no cigar. You can reach a really decent baudrate accuracy, if you pick the right crystal. 11.059MHz, 14.745MHz and other Baudrate Vouched speed (you know those we often forget ) would do the trick with a regular USART (not with built-in bit banging solution.. even though 8 MHZ would probably work fine with DEBUG)
    No pain no gain, those crystal speed aren't "standard value", well not listed in PBP supported list, so you'll need to tweak you delay, if your application is timing sensitive.
    Hello, dear mister_e and aratti,
    thanks for your replay. I will test both of your expert and your idea, but i think the mister_e have been right, if i will select the right crystal, i can reach the desire boud rate, and can do it for my project, and use the right pin of USART madule in PIC16, i can connect and get data in 115200 bps of my nokia 3310.
    i will test it, and then i will replay the result to you.
    thanks.
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 23:04
  2. Can't read an sms Using TC35i & 16F690
    Last Post: - 4th October 2009, 23:41
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. pic to mobile
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 19th July 2005, 19:26
  5. SMS decoding / encoding using PIC!
    By bitmaniac in forum mel PIC BASIC Pro
    Last Post: - 19th March 2004, 08:03
