mostly right, but no cigar. You can reach a really decent baudrate accuracy, if you pick the right crystal. 11.059MHz, 14.745MHz and other Baudrate Vouched speed (you know those we often forget
) would do the trick with a regular USART (not with built-in bit banging solution.. even though 8 MHZ would probably work fine with DEBUG)
No pain no gain, those crystal speed aren't "standard value", well not listed in PBP supported list, so you'll need to tweak you delay, if your application is timing sensitive.
