Read & Send SMS from a Mobile using PIC Microcontroller
Results 1 to 19 of 19
    Jun 2005
    Up the bush, Western Plains, NSW Au
    After wading thru piles of info on Nokia and AT commands, I found (can't remember exactly where) that you cannot simply do AT commands to tell a Nokia to send SMS messages. This resulted in my trrowing away my plans to use Nokia gear and moving over to Sony Ericsson, MUCH easier to work with considering their AT command set DIRECTLY controls their onboard modem directly.
    Peter Moritz.
    New South Wales,
    Australia.
    May 2008
    Italy
    Chakkarapani, you are not saying much about your hardware. I hope you have used a max3232 to connect the Fbus to the PC otherwise you have burned the Rx line. (Fbus is 3.3 Volts)
    http://www.datasheetcatalog.org/data...ts/max3232.pdf
    Most of the AT command (not all) works also with Fbus.
    Alberto
    Hi friends,
    I'm in the same way to perform this project with PIC and Nokia 3310.
    But i find out the PIC 16F84A only can support the 9600 bps Baudrate and less than it. But the nokia 3310 FBUS, only can support the 115200 bps baudrate.
    which PIC micro have this buadrate, that i can connect it to nokia?
    we know, to open the bus between the nokia and PIC, we must to send 'U' 128 times. and then the bus is opened to communicate data between them selfs.
    any Idea for this? for the same baud rate of nokia 3310 in PIC?
    thanks in advanced.
    May 2008
    Italy
    Use a pic 18Fxxxx like 18F2585 for instance, with a 40 Mhz xtal oscillator.
    Here the setting for the EUSART @ 115200,n,8,2 (Obtained with Mister E PicMulticalc)
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $24   ' Enable transmit, BRGH = 1
    SPBRG = 86    ' 115200 Baud @ 40MHz, -0,22%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    Al.
    Quote Originally Posted by aratti View Post
    SPBRGH = 0
    Al.
    hey dear atari, thanks for ur replay, but i need 115200 baudrate, 8 bit data, no parity and 1 stop bit.
    i don't need the high frequency for processing, but i need high baud rate to communicate with the nokia 3310, if i can do this with the PIC16f84A or other 16 series for example 16F877A(40 Pin)
    i need to reach this baud rate(115200) to do my project.
    i can't use the other PIC, because i need to complete my proj earliyer. and if i use the other pic, i need to learn about them, and i don't have enough time.
    Please help, if u can. thanks in advanced.
    Excuse me, i have some mistake about spelling your name, i'm so ashamed of this.
    May 2008
    Italy
    abbas.khodaeian, I am sorry but you cannot reach an acceptable boudrate of 115200 with 16F series even with a 20 Mhz oscillator.
    If you want to use the 16F84a, then you must change the phone type and use a brand with boudrate @ 9600 (siemens for instance. make sure they work in text mode)
    The high frequency clock and the pic 18F are necessary to reach the high boudrate required by your nokia 3310.
    Al.
    Mar 2009
    Alberto
    Hi aratti , Can you please give me a schematic for connecting SIM300CZ (www.sim.com) and pic 16F877A. mainly the Tx Rx line
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 22:04
  2. Can't read an sms Using TC35i & 16F690
    Last Post: - 4th October 2009, 22:41
  3. HARDWARE I2C SAMPLE CODE question
  4. pic to mobile
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 19th July 2005, 18:26
  5. SMS decoding / encoding using PIC!
    By bitmaniac in forum mel PIC BASIC Pro
    Last Post: - 19th March 2004, 07:03
