calculate time between pulses
Results 1 to 20 of 20
    Wink addendum ...
    Gioppy is bright right ...
    so let's add :
    IF period.7 then
    Period = period/2
    scale = 2
    scale = 1
    intermediate = 60 * 1000 / prescaler_value ' Compulsory !!!
    ' ( no "intermediate CON xxx" allowed )
    ' Disable interrupts ... if some used !!!
    Dummyvar = 1000 * intermediate
    rpm = DIV32 period
    rpm = rpm / scale
    Jun 2006
    Default thanks guys
    thanks for ur help.
    I am also interested in what Mr. Wolf mentioned:using PULSEIN with flipflop.would u shed some light on it also.
    thanks
    Pinckney, Michigan
    In short, what the flip-flop does for you, when measuring frequency, such as in a tachometer application, is it negates the need to measure the duration of the high portion of the period, then switch context and measure the duration of the low portion of the period. The time it takes to switch contexts (jump to another section of code) will be lost, and your measurement will be innacurate.
    The flip-flop makes one long pulse, spanning the entire period of the tach signal, so that a single PULSEIN command can accurately measure the duration of the period.
    For an explanation of the flip-flop idea go to the following Parallax URL:
    http://www.parallax.com/dl/appnt/stamps/bs1appnotes.pdf
    Scroll down to the "Practical Pulse Measurements" section.
    For the complete blow-by-blow as to how I implemented rotor tachometers on my helicopter go to the following URL:
    http://www.basicmicro.com/downloads/docs/RRPM.pdf
    Sep 2005
    Campbell, CA
    I have a PIC reliably reading 10 fan tachometers while it is doing other things. Something to keep in mind is that if your input signal is at all noisy, a simple period measurement may not result in a stable reading, since noise can easily affect a single reading. It is best to take a an average over a period.
    My method involves running a timer interrupt with a period shorter than the shortest expected "high" or "low" tachometer time. The interrupt service routine reads the port bits, and XORs them with the last reading of those bits. If the bit has changed, a counter is incremented. There is one counter for each fan to be monitored. The interrupt service routine keeps track of how many times it has run, so after a period of time (say a quarter or a half-second) it stores the individual counts. Simply multiplying the number of counts by a fixed value yields the RPM.
    The ISR is written in assembly, but this approach has several advantages:
    It doesn't require any external hardware
    It averages the counts over a short period, so the readings are stable even in the presence of noise.
    It works when the duty cycle is far from 50%.
    It runs in the background, so you can process other tasks at the same time.
    If you choose this approach, I can send you the code.
    Charles Linquist
    Cool
    your saying it counts all 10 inputs while using just one timer? I'd like to see that code! sounds sweet.
    Sep 2005
    Campbell, CA
    OK, here you go.
    The interrupt period is 500uSec.
    All transitions in .5 seconds are added, since FanClock has a count value
    of 1000. 500E-9 X 1000 = .5 seconds.
    '------------------ Timer 0 interrupt handler-----------------------------------
    Asm
    ReadTachs
    movlw 0xEC ; Reload TMR0
    movwf TMR0H
    movlw 0x7E
    movwf TMR0L
    bcf INTCON,2 ; Clear the TIMER0 interrupt flag
    infsnz MasterClock
    incf MasterClock + 1 ; 16 bit Master system clock
    btfss TPE,0 ; Fan counter active gate
    bra CheckFans
    bra DoneForNow
    CheckFans
    infsnz FanClock
    incf FanClock + 1 ; 16 bit loop counter
    movlw 0x03 - 1 ; 1000 = 0x3E8, but must have one less
    cpfsgt FanClock + 1 ; to compare with greater than
    bra FanRoutine
    movlw 0xE8 - 1 ; Again, subtract one
    cpfsgt FanClock
    bra FanRoutine
    bsf TPE,0 ; Set the bit if completed 1000 loops
    clrf FanClock
    clrf FanClock + 1
    bra DoneForNow
    FanRoutine
    movf PORTB,0,0 ; Read the port bits all at once
    movwf Temp,0 ; Copy port into temp register
    xorwf OldPortB,0,0 ; XOR bits to see which ones have changed
    movwf changedB,0 ; Bits of changed ports will be set to "1"
    movff Temp,OldPortB ; Save the register for next pass
    movf PORTC,0,0
    movwf Temp,0
    xorwf OldPortC,0,0
    movwf changedC,0
    movff Temp,OldPortC
    movf PORTD,0,0
    movwf Temp,0
    xorwf OldPortD,0,0
    movwf changedD,0
    movff Temp,OldPortD
    Fan1
    btfss changedB,0
    bra Fan2
    infsnz Fan1Counter
    incf Fan1Counter+1
    Fan2
    btfss changedB,1
    bra Fan3
    infsnz Fan2Counter
    incf Fan2Counter+1
    Fan3
    btfss changedB,2
    bra Fan4
    infsnz Fan3Counter
    incf Fan3Counter+1
    Fan4
    btfss changedB,3
    bra Fan5
    infsnz Fan4Counter
    incf Fan4Counter+1
    Fan5
    btfss changedB,4
    bra Fan6
    infsnz Fan5Counter
    incf Fan5Counter+1
    Fan6
    btfss changedB,5
    bra Fan7
    infsnz Fan6Counter
    incf Fan6Counter+1
    Fan7
    btfss changedC,0
    bra Fan8
    infsnz Fan7Counter
    incf Fan7Counter+1
    Fan8
    btfss changedC,1
    bra Fan9
    infsnz Fan8Counter
    incf Fan8Counter+1
    Fan9
    btfss changedC,5
    bra Fan10
    infsnz Fan9Counter
    incf Fan9Counter+1
    Fan10
    btfss changedC,4
    bra DoneForNow
    infsnz Fan10Counter
    incf Fan10Counter+1
    DoneForNow
    INT_RETURN ; Return from the interrupt
    ;---------------------- End of Timer 0 Int handler -----------------------------
    Charles Linquist
    Smile ooh more to learn!
    Thanks for posting that!
  1. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 13:44
  2. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  3. Replies: 1
    Last Post: - 18th April 2006, 20:11
  4. How to calculate machine time in basic code?
    Last Post: - 24th February 2006, 00:44
  5. anyone knows how to calculate muslim prayer time?
    By luqman83salleh in forum mel PIC BASIC Pro
    Last Post: - 6th September 2004, 10:54
