DS1820 and 18f2550
Results 1 to 8 of 8
    Sep 2007
    Default DS1820 and 18f2550
    There are so many threads/ articles on the net about this but I am still failing to get it working. If anyone has a good idea, please HELP ME!
    I have the DS1820 wired with 5 volts on pin 3, a 4.7 k pullup on pin 2 to PortA.0 on Pic and pin 1 to gnd. I have measured voltages with and without the 18f2550 in place to verify the voltage on pin 3 of DS1820 is coming from pullup. I am 99.999% certain electrically it is all good.
    My fuse are setup as follows as I have USB comms running but not for the duration of the DS1820 tests just to make it simple. I am using a 20Mhz OSC and USB comms works fine so I am confident about Osc config etc at least for USB. OW doesn't have any special requirements does it?.
    	__CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
                                ;              ; USB clock source comes from the 96 MHz PLL divided by 2
                                ;              ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
                                ; No prescale (4 MHz oscillator input drives PLL directly)
    	__CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
                                ;                  ;               ; Oscillator Switchover mode disabled
                                ;                  ; Fail-Safe Clock Monitor disabled
                                ; XT oscillator, PLL enabled, XT used by USB
    	__CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
    	__CONFIG    _CONFIG2H, _WDT_OFF_2H
    	__CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
    	__CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    I have tried 2 pieces of code. First one just outputs
    Busy
    Busy
    Busy
    To Hyperterm:
    DEFINE      OSC 48          ' We're using a 20MHz oscillator
    ADCON1 = 7 ' Make pins digital
    DEFINE HSER_SPBRG 225 ' 9600 Baud @ 48MHz, 0.0%
    SPBRGH = 4
    HSEROUT [13,10,"Starting"]
    Comm_Pin    VAR	PortA.0     ' One-wire Data-Pin "DQ" on PortC.0
    Busy        VAR BIT         ' Busy Status-Bit
    R_Temp      VAR	WORD        ' RAW Temperature readings
    TempC       VAR WORD        ' Temp in deg C
    TempF       VAR WORD        ' Temp in deg F
    Float       VAR WORD        ' Holds remainder for + temp C display
    Cold_Bit    VAR R_Temp.Bit11' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    Real_Cold   CON 1           ' Define Real_Cold = 1
    BAUD        CON 16468       ' N9600 for serial LCD
    DISP        VAR PortB.0     ' Pin to drive serial LCD
    Deg         CON 223         ' Data to display Deg ° symbol
    CLR         CON 1           ' CLR LCD command
    LINE1       CON 128         ' LCD line #1
    LINE2       CON 192         ' LCD line #2
    LINE3       CON 148         ' LCD line #3
    LINE4       CON 212         ' LCD line #4
    INS         CON 254         ' LCD command mode parameter
    Sign        VAR BYTE        ' +/- sign for temp display
    Dummy       VAR BYTE        ' Dummy for Div32
    Start_Convert:
        OWOUT   Comm_Pin, 1, [$CC, $44]' Skip ROM search & do temp conversion
        Pause 2000
    Wait_Up:
        OWIN    Comm_Pin, 4, [Busy]    ' Read busy-bit
        hserout [13,10,"Busy"]
        IF      Busy = 0 THEN Wait_Up  ' Still busy..?, Wait_Up..!
        OWOUT   Comm_Pin, 1, [$CC, $BE]' Skip ROM search & read scratchpad memory
        OWIN    Comm_Pin, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]' Read two bytes / end comms
        GOSUB   Convert_Temp
        GOTO    Start_Convert
    Convert_Temp:                 ' +32.0 to +257 F
        IF      Cold_Bit = Real_Cold THEN Yikes ' If Cold_Bit = 1, it's below "0" deg C
        Sign  = "+"
        Dummy = 625 * R_Temp      ' Multiply to load internal registers with 32-bit value
        TempC = DIV32 10          ' Use Div32 value to calculate precise deg C
        Dummy = 1125 * R_Temp
        TempF = DIV32 100
        IF TempF >6795 THEN ' Over 99.5 deg F..?
           TempF = TempF + 3200
           HSEROUT [13,10, " TempF = ",Sign,DEC TempF DIG 4,_
           DEC TempF DIG 3,DEC TempF DIG 2,".",DEC2 TempF,Deg,"F "]
           HSEROUT [13,10, " TempF = ",Sign,DEC TempF DIG 3,_
        TempC  = (R_Temp & $0FF0) >> 4 ' Mask middle 8-bits, shift into lower byte
        Float = ((R_Temp.Lowbyte & $0F) * 625) ' Lower 4-bits of result * 625
        HSEROUT [13,10, " TempC = ",Sign,DEC TempC,".",DEC Float,Deg,"C "]
        HSEROUT [13,10, "Raw", IBIN16 R_Temp]
    Yikes:                      ' Display full range -C to -F conversion
        Sign   = "-"            ' Display - symbol for negative temp
        Dummy  = 625 * ~R_Temp+1' Multiply to load internal registers with 32-bit value
        TempF  = ~R_Temp / 16   ' Begin conversion from -C to deg +/-F
        IF TempF >=18 THEN      ' Check for -degrees F "-18 C = -0.4 F"
           TempF   = ((((TempF + 50) * 9) /5) -122) ' -C to -F below -17 deg C
           HSEROUT [13,10, " TempF = ",Sign, DEC TempF,Deg,"F     "]
           HSEROUT [13,10, " TempC = ",Sign,DEC TempC DIG 4,_
           DEC TempC DIG 3,".",DEC3 TempC,Deg,"C "]
        ELSE                    ' Else result = +deg F
           TempF   = ((((-TempF + 50) * 9) /5) -58)' -C to +F below 32.0 deg F to -17 deg C
           HSEROUT [13,10, " TempF = ","+",DEC TempF,Deg,"F     "]
    The second really simple bit of code just outputs 00.0
    define OSC 48
    ADCON1 = 7            ' Set PORTA to digital
    SPBRGH = 4
    DQ var PORTA.0
    temp var word
    loop:
    owout DQ,1,[$cc]
    owout DQ,0,[$44]
    Pause 2000
    owout DQ,1,[$cc]
    owout DQ,0,[$be]
    owin DQ,0,[temp.byte0,temp.byte1]
    temp=temp*5
    HSEROUT [13,10, " Temp = ",DEC2 temp/10,".", dec1 temp," ","C"]
    goto loop
    These bits of code come from sources that swear they work. What else could it be?!?!! For now I will try and send something else down USB to VB!!
    Hope someone can help.
    Thanks a lot
    Rich
    Question
    Hi, Rich
    I have a DS1820 "on board" ... I look at that.
    Here is an excerpt of my test program:
    ' Start temperature conversion
    mainloop: OWOut DQ, 1, [$CC, $44 ]
    ' Check for still busy converting ( ~ 4500 times ... )
    waitloop:
    INPUT DQ
    If NOT DQ Then waitloop
    ' Read the temperature
    OWOut DQ, 1, [$CC, $BE ]
    OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    ' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)+ offset
    Lcdout $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " ",$DF,"C"
    ' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature)
    temperature = (temperature */ 461) + 3200
    Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " ",$DF,"F"
    the major thing is see is here :
    as you receive more than 16 bits ... and your "buffer" is only 16 bits.
    The Scratchpad is always FULLY read ( 8 bytes ), so you must skip the last locations.
    see datasheet on page 8 for scratchpad details.
    Sep 2007
    Thanks for your help mate,
    I tried using your code but my problem is earlier on than the number of bytes being read. I put this 'turn LED line on' line after the wait loop. The LED never comes on. My ds1820 is never being ready I guess. I have double checked wiring. I know it's an odd one. Any more ideas just to get me past the wait loop. Once I am past there I can work the rest out from your fabulous info!
    high PORTA.5
    ' the LED never comes on (but of course it does if I put the line before the loop!)
    Rich
    Ok,
    Reading closer the datasheet shows there are time slots for writing and reading ...
    so, rub out your PAUSE 2000 ...
    but keep on polling DQ !
    Sep 2007
    Thanks again mate but your code, the code I tried last, didn't have a pause 2000. That was mine. Your code never gets past the wait loop either. Here is code again for clarity. I appreciate it isn't going to work later in code as I haven't done anything with offset etc but there is no point till I get past the wait loop for ds1820 to become ready.
    define OSC 48
    SPBRGH = 4
    DQ var PORTA.0
    temperature var word
    count_remain var word
    count_per_c var word
    offset var word
    waitloop:
    INPUT DQ
    high PORTA.5 ' turn on LED if it gets past this point
    'Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " ",$DF,"F"
    HSEROUT [13,10, " Temp = ",DEC (temperature / 100), ".", DEC2 temperature, " ","F"]
    goto mainloop
    Try ADCON1 = 15 VS ADCON1 = 7. You are leaving most of PORTA setup as analog inputs.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Did you disable Porta Comparators ??? looks no ...
    Default setting ... ok, but ...
    EXAMPLE 10-1: INITIALIZING PORTA
    CLRF PORTA ; Initialize PORTA by
    ; clearing output
    ; data latches
    CLRF LATA ; Alternate method
    ; to clear output
    ; data latches
    MOVLW 0Fh ; Configure A/D
    MOVWF ADCON1 ; for digital inputs
    MOVLW 07h ; Configure comparators
    MOVWF CMCON ; for digital input
    MOVLW 0CFh ; Value used to
    ; initialize data
    ; direction
    MOVWF TRISA ; Set RA<3:0> as inputs
    ; RA<5:4> as outputs
    Even Microchip does it !!! ...
