RF development board
Results 1 to 3 of 3
    Default RF development board
    Hi Folks,
    We have a new RF receiver board for the linx Technologies long-range LR series receiver modules.
    It's available as a bare PCB, PCB with pre-soldered LR receiver, and full kits with PBP code examples
    for decoding Holtek HT12E & HT640 encoders, and code for creating your own 8-pin encoder/decoder
    ICs.
    http://www.rentron.com/QRELAY.htm
    -Bruce
    tech at rentron.com
    amitrana3348's Avatar
    amitrana3348 Guest
    Default holtek decoder
    hello sir,
    I am having a txd-433-kh2 and rxd-433-kh2 pair
    when used to turn on Contact-er of 3-phase motor, the output of receiver is oscillating
    this is because the interference of motor to the holtek decoder,
    if you please share the code of HT640 decoding it would be of great help and I would try to decode the code on microcontroller,
    I referred your last post on same topic but i was unable to interpret the code written there to convert it to my atmega32 microcontroller in C program, if you have C program, please share it
    thanks
    The Linx KH2 transmitter uses the Holtek HT640 encoder, and I have posted code to decode this particular IC here http://www.picbasic.co.uk/forum/showthread.php?t=6581
    Of course, since this is a forum for MicroEngineering Labs compilers, the code is for the PBP compiler.
    If you need this translated to an 8051 core device, in C, I can do that, but there will be a charge for the conversion work.
    -Bruce
    tech at rentron.com
  1. microcode studio and ql200 development board
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 1st October 2015, 17:28
  2. Pic Development Board
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 9th September 2010, 17:14
  3. Pretty cool display and development board PIC_LCD3310
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 17th April 2010, 10:05
  4. Development Board Recomendations ???
    By tico in forum mel PIC BASIC Pro
    Last Post: - 27th March 2007, 01:27
  5. Development Board
    By carl_schell in forum Adverts
    Last Post: - 21st July 2004, 08:39
