16F688 port puzzle
Results 1 to 10 of 10
    Seems to be an analog port related stuff...
    let's open the 16F688 datasheet... mmm i see...
    what about if you add...
    ANSEL = 0
    at the top of your code?
    Isle of Man
    Default 16F688 port puzzle - solved
    Yup, that solved the problem!
    Now I realy must try to understand what ANSEL actually does ....
    A BIG thanks again to Mister_E!
    In that datasheet, ANSEL is not really well documented like most other PIC registers. You need to read between the line. Open the PDF and search for ANSEL, you'll find few hits.
    Basically each bit of ANSEL is assigned to a ADC channel. Bit 0 to AN0, Bit 1 to AN1 and so on. POR value is 255, %11111111. If a specific bit is set, the corresponding channel will be set as analog, if it's clear, it's digital. ANSEL=0 will obviously set every channel to digital.
    EDIT: erm... ok it's documented... Register 4-3, PDF page 36. It's just not in the ADC section... as it 'should be'. Why??? Because
    Isle of Man
    Cool 16F688 Port puzzle
    Yes, I also did a search for ANSEL in the datsheet and found nothing of much use.
    Although it works in this example, I am still unclear why ANSEL has any effect on the behaviour of LEDs on PortC.3 and PortC.5 which are not configurable for analogue.
    Miip! C.3 is also AN7...
    In theory ANSEL.7=0 should also work.
    PS: Read again post 4, i changed it while you replied.
    Using a analog port as digital output will do weird things...
    Question
    now why isn't this stuff in the faq section? ansel cmcon etc etc
    Isle of Man
    Smile 16F688 Port puzzle
    A big thanks again Mister_e. Indeed PortC.3 is analogue too. Sorry I missed that! The datasheet could be much clearer on issues like this or, as Nomad says, such pearls of port configuration wisdom could be distilled into a HOW TO section of FAQs.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by nomad View Post
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
    Last Post: - 14th November 2008, 17:25
  3. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 12:25
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 15:21
