Miip, that's the one MPLAB/MPASM use, the one you need to find and modify is located in your PBP folder and should, once modified, looks like the following
If you're using MicrocCode studio, click on View>Compile and Program Option In Compiler tab it should write the compiler path just over the Find automatically button. In my case C:\pbpCode:;**************************************************************** ;* 18F6520.INC * ;* * ;* By : Leonard Zerman, Jeff Schmoyer * ;* Notice : Copyright (c) 2007 microEngineering Labs, Inc. * ;* All Rights Reserved * ;* Date : 07/09/07 * ;* Version : 2.50 * ;* Notes : * ;**************************************************************** NOLIST ifdef PM_USED LIST "Error: PM does not support this device. Use MPASM." NOLIST else LIST LIST p = 18F6520, r = dec, w = -311, w = -230, f = inhx32 INCLUDE "P18F6520.INC" ; MPASM Header ;__CONFIG _CONFIG1H, _OSC_XT_1H ;__CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H ;__CONFIG _CONFIG4L, _LVP_OFF_4L NOLIST endif LIST EEPROM_START EQU 0F00000h BLOCK_SIZE EQU 8
This should cure the problem.
