Crystal "calibration" - how to (a simple way)?
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Crystal "calibration" - how to (a simple way)?
    Hello,
    I have a 16F690 I with a 4MHz crystal. As specified in it's datasheet, I use two 22pF caps (C1 + C2).
    I'm building a time depend circuit (charger) where a +/- minute accuracy over 10 hours is not important.
    Nevertheless, I'd like to know how to "calibrate" the crystal to make it more accurate.
    I read this: http://ww1.microchip.com/downloads/e...tes/00588b.pdf and still don't know if I'm going to pull the trigger
    Then, I found this: http://ww1.microchip.com/downloads/e...Doc/70054b.pdf witch looks a little more understandable (comprehensible?) to me.
    Finally I read this one: http://ww1.microchip.com/downloads/e...tes/00826a.pdf.
    I was looking for a "simple way" to check the crystal's accuracy.
    Does anyone have this explanation for me?
    I only have a cheap PC 20MHz oscilloscope so I don't expect to make lab measurements...
    Roger
    Hi Roger,
    A quick way to adjust the calibration might be to replace the fixed capicitors with variable ones and tweak them until your circuit runs at the expected time.
    JS
    This is one way of doing, thank you Joe S. But this can take a lot of time...
    Isn't there another more "scientific" way to measure the correct oscillation frequency?
    I found some information in previous posts (can't find it right now) about measuring the crystal but there was an issue with the capacitance of the probe making the result inaccurate.
    If I make a short code toggeling a port and me measuring it with my (poor) oscillo, would the result be somehow reliable?
    Roger
    Sure there is, hook up a frequency counter, an accurate one, time your circuit's operation and log both entries, adjust as in above and time it again and compare OSC speed to circuit change, you then have a ratio to work from. OR use an RTC.
    Oh yeah, I thought of one more way, if you have an accurate radio reciever, you can check for the oscillators harmonic frequencies at different dial settings, 5,10,40,80 mhz and so on up and down the dial. Or use scope to form Lissajous patterns. example link http://www.egr.msu.edu/classes/ece48.../lissajous.htm
    Just curious Roger, why all the fuss for a battery charger?
    HTH
    JS
    Lightbulb
    Hi, Flotul
    The best and easier way is to buy quality crystals ... ( from Farnell i.e...).
    The second way is to use External DIP oscillators ...
    The Third way is to buy a good Freq meter ....
    I also think you can get precise 10 Mhz by radio ... ( see Radio ham ...)
    You can also correct time every minute with a DCF module !!!
    What I usually do is to play with the timer preload value ... fits most of time !!!
    One of the electronician's main headache has always been to have home good references ... ( Volt, freq, temp,pressure ...humidity ( LOL ! ) )
    Thanks Joe S,
    Today I build a battery charger and tomorrow, what will it be? I just take the opportunity of this circuit to learn a little more about the accuracy my PIC can (or could) have.
    Of course, there is absolutely no need to have a lab's chronograph to charge batteries...
    Merci Alain. What is your measuring point to evaluate your precision? Is it a port as I mentionned in post#3?
    Roger
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  2. Sharing Crystal with 2 IC's
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 10th January 2013, 13:33
  3. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  4. 20 Mhz Crystal, simple blinking LED
    By BenjaminsShinob in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 05:06
  5. Replies: 1
    Last Post: - 30th June 2004, 08:07
