Looking at you drawing I can see 2 things wrong
The RW pin needs to go to ground
and your RS pin need to be connected to the pic dependig on which pin you have got declared in your code
I see 1nF as C1 and C2 near the xtal.
That value is much too high for a xtal. you should change it into 47 pF for both capacitors.
