Pic12F675 serial voltmeter
Results 1 to 23 of 23
    Aug 2003
    So it serialy outputs the monitored voltage continuously?
    Looks great for keeping an eye on a solar installation when you can't
    really keep an eye on it.
    Art.
    Art.
    Yes; every second.
    I have modified the vb6 program that receive, display and plot the battery voltage.
    If someone want play with it, source code and BattMonitor.exe are attached.
    Improvement and bug fix are welcome.
    I use it with true serial port (com1-2), i do not know if it works with usb serial adapter.
    Gianni
    Aug 2003
    Thanks a heap,
    I'll give it a go as my solar installation becomes more developed.
    Aug 2003
    Idea for improvement, I see GPIO 1 & 2 are free, so why not set GPIO1 as output
    and switch it high if the solar panel voltage suddenly drops to say... zero.
    You could call that status bit ALARM!
    http://www.wind-sun.com/ForumVB/showthread.php?t=1611
    Or I'll simply do it myself when I get motivated
    Cheers Art.
    Yes that is possible.
    Please note that the voltage measure implement a digital low pass filter, so the response is smoothed.
    IMHO a simple micro switch can do the job.
    Gianni
    Aug 2003
    It would be harder to produce a constant voltage to satisfy your program if panels go missing than just cross two wires,
    and it costs zero dollars if you're already using your circuit, and I could forget about loop back wires.
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  2. PIC12F675 problem with port 5
    By NL2TTL in forum mel PIC BASIC
    Last Post: - 5th June 2009, 01:23
  3. Pic12f675 Serial woes
    By simongie in forum Serial
    Last Post: - 30th April 2009, 21:41
  4. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 15:04
  5. PIC12F675 trouble
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 18:40
