PWM with a PIC
Results 1 to 5 of 5
Thread: PWM with a PIC
    Jun 2005
    Wisconsin
    Normally PWM is used when you want to dim a DC load. In your case you are trying to dim an AC load, this is done very differently. In short AC dimming requires a zero cross sense, and an interrupt timer.
    For more detail on how AC dimming works check out this website:
    http://www.dv-fansler.com/Computer%20Lights/dimmers.htm
    NOTE: You can't dim inductive loads with this method, only resistive loads like light bulbs.
    Jun 2007
    Mansfield, UK
    Thanks. ill have to check that link when i get home because its blocked at work.
    Ive been thinking about some LED lighting projects too. How would i dim those? I would assume its more or less the same idea but LEDs dont glow for a while after the power goes off like bulbs so wouldnt they just flash rapidly?
    Is it really complicated to dim things like transformers? Ive seen lighting controllers do it before
    Dimming theory is almost always the same, the driver circuit may need to be changed.
    Do a search for snubber, Inductive load dimmer (dimming/driving), snubberless Triacs.
    For LEDs... don't worry, you don't need any synch. Just a high enough frequency will work.
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  2. how can i stop the pic from sending a PWM???
    By texas5 in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 17:12
  3. using all pins of pwm in pic 18f2431
    By jorgequesada in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 21:43
  4. pic 18Fxx31 PWM module
    By dirace in forum mel PIC BASIC Pro
    Last Post: - 15th May 2005, 19:51
