18F452 PC Comminication Problem
Results 1 to 4 of 4
    Dec 2005
    Corum,Turkiye
    Default 18F452 PC Comminication Problem
    i want to comminicate with 18F452 to PC Visual Basic. but i think my problem is OSC . Coz i m using 10 MHZ Quartz and with PLL so 40 MHZ OSC... Maybe it doeasnt senkron.
    if had any project pls send me.. or same project...
    Thanx already now...
    I would suggest you check everything in simple block and step by step
    1. Simple led blink or PWM : This will confirm your configuration fuse and OSC setting are fine
    2. Use low baudrate 2400-9600 baud and dump some text string to your PC using Hyperterminal or MicroCode Studio Serial communicator.
    3. read the simple VB6 tutorial bellow
    http://www.rentron.com/VisualBasic.htm
    4. post the whole project (PIC code, config fuses, VB code and schematic) here.
    good luck
    Dec 2005
    Corum,Turkiye
    Default Hi
    This program steps working... only comm not worked. i ll send it... ok. Thanx..
    a while back i did a really nifty terminal example. Maybe this would help to start
    http://www.picbasic.co.uk/forum/showthread.php?t=1833 see post #4
    HTH
  1. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 00:21
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. 18F452 compile problem
    By pcbb in forum General
    Last Post: - 21st April 2007, 03:16
  4. Replies: 5
    Last Post: - 20th March 2006, 02:34
  5. PC - PIC problem...
    By menhwa in forum Serial
    Last Post: - 20th February 2006, 20:57
