ammeter with the pic16f876A
Results 1 to 10 of 10
    and what is the easier way to measure the current with the analogic ports of the 16f876?
    Question
    Quote Originally Posted by lutherblisset View Post
    You have the whole schematics ... and the kit explanations.
    What further do you need ??? the program for free ???
    Hangover, Germany
    Cool
    Where is the problem ?
    1. You must know the maximum current.
    2. You can choose your shunt (don't forget the heat!!!!)
    3. You use a OPAMP as an amplifier for the voltage to maximum 5V for maximum current trough the shunt. I use an LT1490 (rail-to-rail) for 5V-supply and good quality.
    4. Measure the voltage !
    (I use the lm385-2.5 as a reference. I measure the voltage of one port an the voltage of a port with the lm385 on it to calculate the correct voltage, because the supply-voltage may be incorrect or spread widely. The normal 7805 is worse, I use a 78M05CDT instead.)
    can be the INA138 a good idea instead of the operational?it is a "High-Side Measurement Current Shunt Monitor, Current Output",it directly convert voltage to current
  1. A2D issues on PIC16F876A
    Last Post: - 31st July 2008, 15:06
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Runing a PIc16F876A
    Last Post: - 7th January 2007, 13:54
  4. PLEASE HELP ME! pic16f876a and AD tlc4541
    By luca_sheva in forum mel PIC BASIC
    Last Post: - 1st February 2005, 18:32
  5. how to get PCF8574 and PIC16F876A work together
    By nomada in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 03:07
