Drive multiple LED with one PWM
Results 1 to 4 of 4
    Aug 2005
    Question Drive multiple LED with one PWM
    Hi all!
    I want to regulate brightness of 6 LED at the same time with one PWM modulated output from a PIC 18F1320. What kind of driver can I use? Every LED has about 30mA current consumption.
    Very Thanks!,
    Francesco
    microuser . 1 2n3904 transistor with 1K resistor in series with base and connected to your favorite PIC pin. Transistor Emitter connected to ground. Transistor Collector connected to last cathode of 6 series connected LEDs. 47 Ohm Resistor in series with first Anode connection of LED string connected to 12 volts.
    Aug 2005
    Thanks Dave!
    What do you think about a BC517 with LEDS in parallel?
    I have to choose the better solution
    one or the other will work. It's not as this critical. BC517 is a darlington. 1 AMP Ic... more than enough.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  4. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  5. LCD will not start
