EPWM control
Results 1 to 12 of 12
Thread: EPWM control
    Jun 2007
    Merango, IL
    Thank you mister_e again for your input. I think I might have made some headway on this project. Things I have chaged from last sch:
    1. Removed and placed jumpers instead of the 470ohm gate resistors.
    2. Place a 25V 470uF elect Capacitor for the 12V on the motor.
    3. Placed 1uF 50V Ceramic caps on the 12V power for the driver chips, and across the H-Bridge 12V.
    These seem to have cleaned the signals up a lot. I know can run the test code and a have the motor run back and forth forever. The load of each of the 2 motors is 5A each, I use 100uF for each 1A as a rule of thumb that I had forgotten.
    The Back emf diodes are included in the mosfets, and I also have TVS to help with these problems. If you have anything else please free to let me know. I will try to keep everyone updated.
    Thank you,
    Anthony
    yeah but usually those internal diode are just simply too slow...
    I think we don't use the same rules of thumbs 1000uF/Amp here... maybe i'm wrong?
    When you said.. Place a 25V 470uF elect Capacitor for the 12V on the motor.
    you mean in parallel with the motor??? not sure if you really need it. And.. mmm, if it's not a not-polarized type, you may have some problem one day or another... If it's only on the Vdd rails then.. that's ok.
    Across the driver i would suggest 10-47uF tantalum + 0.1 uF ceramic.
    Enjoy! and great to know it solve most of the problem
  1. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 16:40
  2. pt2258+16f877 how can i use for 5.1 volume control ?
    By whyliving in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 18:51
  3. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 14:26
  4. Allow better control of text in GUI
    By Archangel in forum PBP Wish List
    Last Post: - 19th February 2007, 14:25
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
