Need some help converting code for a PIC16F84 to an PIC16F886 [yes ASM]
Results 1 to 4 of 4
    Sep 2007
    Default Need some help converting code for a PIC16F84 to an PIC16F886 [yes ASM]
    I wanted to expand on some pre-existing code so I could insert a ones, tens, hundreds button to a speed alert system.
    The problem is the code is for a PIC16F84 with only an UP and DOWN button. As its impractical to cycle up and down to set a speed limit of say 40 or 60 or 80 (which would be quite common ) I wanted to add 3 extra buttons. With limited PINS i've decided to use a PIC16F886 and have 28 pins at my disposal.
    I tried to compile the code in MPLAB for an 84 with the PIC hardware specified to an 886 and changed the header file from:
    list P=16F84
    	#include "p16f84.inc"
    	__config _XT_OSC & _WDT_OFF & _PWRTE_ON
    to
    list P=16F886
    	#include "p16f886.inc"
    But its not liking the last line.
    I get the following error:
    Error[126]   C:\PIC LAB\SPEED3.ASM 64 : Argument out of range (not a valid config register address)
    Does anyone know what to do?
    I also realize I may have to remap pins.
    However the 84 uses two bi-directional ports PORTA AND PORTB - and the 886 has an additional port which i can use for extra inputs. So i'm hoping theres no remapping necessary.
    I just need 3 pins for the extra buttons and the EUSART
    If you need to see the corrected code I can post it here in 4-5 posts or attach it as a word document, however I can't guarantee the spacing will be perfect. Below is the latter.
    thanks in advance guys.
    Default Maybe
    MPASM is very picky as to missing or extra spaces, and missing or extra _ _ _ characters.
    In case of doubt, the .INC is handy... look at the end. There you'll discover _CONFIG1 and _CONFIG2
    Try...
    	__config _CONFIG1, _XT_OSC & _WDT_OFF & _PWRTE_ON
    Aug 2004
    Hi:
    The 16f84 has not ADC neither comparators, the 16f886 has. You need the appropiate instructions to disable that functions.
    Greetings..
    Ruben de la Pena
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. Converting compiled code to unsupported PIC
    By jpadfield in forum General
    Last Post: - 20th May 2005, 19:40
  5. Converting Stamp code
    By paul.mcallister in forum General
    Last Post: - 8th February 2005, 11:48
