HPWM - I need 10 bits
Results 1 to 5 of 5
    Default Can we mix PBP and some direct register writes?
    Does anyone know if it is possible to set up HPWM in PBP then fine tune the values with a direct write to CCP1CON<5:4> which control the two LSB?
    This would let me stay with the PBP code I have and add a 'simple?' tweak where the 8 bit steps prove too coarse?
    Cheers
    Brian
    Perth, Australia
    You could try it, but I cant think of an easy way to test if it worked unless you have a scope handy to look at the output.
    Frankly, its not hard at all to set it up by directly writing to the registers. If anything it would be a good learning experience, as i'm sure this wont be the last time you will have to deal with registers like these.
    Last Post: - 14th June 2016, 08:55
  2. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  3. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  4. Need clever way to convert 10 bits to 8 bits
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2005, 16:13
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
