If you want to use the MSSP, (Master Synchronous Serial Port) to receive data simultaneously while sending, then you should let the MSSP do them both.
It'll be a lot simpler.
This example might help, but it doesn't take the CC2500 into account, since I've never seen one ...HTH,Code:SDI VAR PORTC.4 ; Data IN Pin for 18F2420 SDO VAR PORTC.5 ; Data OUT SCK VAR PORTC.3 ; Clock BF VAR SSPSTAT.0 ; Buffer Full Flag CKE VAR SSPSTAT.6 ; SPI Clock Select bit TXbyte VAR BYTE ; Byte to Send RXbyte VAR BYTE ; Received Byte SSP_Init: LOW SCK ; Start with clock and data out (OUTPUT LOW) LOW SDO INPUT SDI ; Input is already Default, but just in case CKE = 1 ; Transmit occurs on transition from ; active to Idle clock state SSPCON1 = %00100010 ; Enable MSSP, SPI Master, CLK idles low, FOSC/64 clk ;_____________________________________________________________________________ Main: TXbyte = $69 GOSUB SendReceive ; at this point, RXbyte will hold the byte that was shifted in at ; the same time TXbyte was shifted out PAUSE 1000 GOTO Main SendReceive: SSPBUF = TXbyte REPEAT : UNTIL (BF = 1) ; wait for MSSP to finish shifting RXbyte = SSPBUF RETURN
