You are correct, I didn't upload the schematic. That is here:
http://www.injektilo.com/PICHelp/schem.bmp
I have a feeling that jumping straight into this form of the project might be too difficult (considering my time constraints). I have come across a more common LED Matrix layout, and I have uploaded the pictures and code here:
http://www.injektilo.com/LEDMATRIX/
Again, I won't be using a 5x7 display, but a handmade 5x5 one. If I use this, it seems as though all the work is done for me (hehe).
My only question is....I want to replace each SINGLE LED with 5 LED's in PARALLEL (since I need to shine this through a diffusive plexi material, so I need the brightness and spread of light). Since they are in parallel they will each receive the same voltage as the single LED...but what about current? Would I need one resistor for each LED in the "parallel cluster" ?
My friend says: the important bit is that each LED should have its own resistor. Otherwise only the LED with the lowest internal resistance will light.
If so, what equation governs the value of each resistor? Argh! I just want to get this project I started over with before I move and then start my serious and gradual study of PIC programming.
Sorry for the change of course (or possible change). Again thanks for all the help guys!
