PIC newbie - took ages to program and i still have bugs
Results 1 to 15 of 15
    I'm not saying that you won't get any help but since this is a forum for PicBasic you MAY not get the help you're looking for. Something like the PICList may be more suitable if you're "writing" in, or having problems with ASM.
    BUT, with that being said, have you selected 16F84 in MPLAB? Configure/Select Device and then point to 16F84.
    /Henrik Olsson.
    Feb 2003
    Salt Lake City, Utah USA
    as a starters,
    C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 323 : Symbol not previously defined (z) Error[113]
    C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 362 : Symbol not previously defined (c) Error[113]
    change commands that look like this (with c or z in them)
    	btfsc	STATUS,z	; check if 0
    to this
    	btfsc	STATUS,Z	; check if 0
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Sep 2007
    Default thanks guys
    Thanks for the help so far - i'll check out piclist and make the above corrections.
    Sep 2007
    Default Thanks for the tips so far
    btw - I got a build succeeded confirmation - however I have the following error messages.
    Clean: Deleting intermediary and output files.
    Clean: Done.
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F84 "SPEED254.ASM" /l"SPEED254.lst" /e"SPEED254.err"
    Message[302] C:\PIC LAB\SPEED254.ASM 542 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 544 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 546 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 770 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 773 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1049 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1051 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1053 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1054 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1056 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1058 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1060 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1065 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1068 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Loaded C:\PIC LAB\SPEED254.cod.
    BUILD SUCCEEDED: Wed Sep 26 07:47:42 2007
    it seems like the error occurs when accessing eeproms or clearing flags
    Does anyone know how to rectify a "Register in operand not in bank 0" error/warning?
    As long as you're sure you did the BANK switching manually, there's no real problem. Unless you may spread some BANKSEL here and there... not sure enough it will solve the warning message so far
    BANKSEL is a nice MPASM tool, it avoid to do the bankswitching yourself AND manually. Same thing as CHK?RP do with PBP. NO YOU DON'T WANT TO USE BANKSEL WITH PBP unless you know some tricks. Even if you know them... i don't find any advantage myself. Maybe Darrel could confirm or contradict it.
    Assuming you already did it (as it seems to be), you just need to disable the warning message with the following
    errorlevel -302
    HTH
    Sep 2007
    well as long as they're only warnings i'll move on to adding to the design.
    thanks
