PIC newbie - took ages to program and i still have bugs
Results 1 to 15 of 15
    Sep 2007
    Default PIC newbie - took ages to program and i still have bugs
    Heres the error log
    Clean: Deleting intermediary and output files.
    Clean: Deleted file "C:\Documents and Settings\\My Documents\speedtemp.mcs".
    Clean: Done.
    Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F84 "SPEED254.ASM" /l"SPEED254.lst" /e"SPEED254.err"
    Warning[207] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 140 : Found label after column 1. (SVNSEG) Warning[207] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 167 : Found label after column 1. (INTER) Error[113]   C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 319 : Symbol not previously defined (z) Error[113]
    C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 323 : Symbol not previously defined (z) Error[113]
    C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 362 : Symbol not previously defined (c) Error[113]
    C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 373 : Symbol not previously defined (c) Message[302]
    C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 501 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 503 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 505 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 707 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 709 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Error[113]   C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 729 : Symbol not previously defined (z) Error[113]   C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 732 : Symbol not previously defined (z) Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 953 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 955 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 957 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 958 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 960 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 961 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 963 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 968 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 970 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Error[113]   C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 975 : Symbol not previously defined (z) Error[113]   C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 1045 : Symbol not previously defined (c) Halting build on first failure as requested.
    BUILD FAILED: Tue Sep 25 12:53:21 2007
    and my code's attached
    Programming language: ASM PIC instruction set
    PIC: PIC16F84
    Any help would be greatly appreciated
    Default Zip ?
    Hi Trickae,
    Welcome, looks like you just joined today, Not too many people will open a zip file from someone they do not know well, so how about you break up that program and let us look at it in pieces if you cannot post it all in one without zipping it.
    JS
    Feb 2003
    Salt Lake City, Utah USA
    Interesting .... I found your code here with google
    http://www.siliconchip.com.au/cms/at...month=November
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Sep 2007
    you've got me -
    the code is legit no malware
    the code is available with current kit based speed alert devices but I need to modify it for a personal project. I just Downloaded MPLAB today and ran the first couple of instructions and found a list of errors. I was expecting everything to be in order:
    Heres the code in full:
    part 1:
    ; File SPEED254.ASM changes from SPEED.ASM to allow speed readings up to 254km/h
    ; Uses assembly code for PIC16F84 microcontroller
    ; This program is for a car speed alarm. It utilises three 7-segment displays
    ; which show the set speed. The speed setting can be altered with up and down pushbutton
    ; switches from 0 to 255km/h in 5km/h steps. When the speed of the vehicle reaches the set speed,
    ; the alarm sounds and an LED lights up. The alarm is a short beep beep sound while the LED
    ; remains lit until the speed is reduced below the alarm speed or the alarm speed is increased
    ; above the vehicles speed.
    ; A rotating magnet or magnets installed on the vehicles tail shaft or drive shaft
    ; trigger an inductive (coil) sensor to detect vehicle speed and this signal is detected via
    ; an interrupt in the processor.
    ; Calibration can be made by setting an alarm speed on the display and then bringing the
    ; vehicle speed up to the alarm speed as shown on the vehicles speedometer.
    ; The Calibrate switch is then pressed. The display will show CAL until
    ; calibrated. Display will show Err (error) if too few pulses or none are present while calibrating.
    ; No calibration allowed in speedometer mode.
    ; Each pressing the Mode switch will cycle between alarm speed indication, speedometer
    ; and off which disables the speed alarm.
    ; Alarm indication occurs for speedometer and alarm speed modes.
    ; Pressing the Up switch at power up will set the speed alarm for either a
    ; repeat warning of overspeed or single alarm. The repeat alarm will produce a tone every
    ; 10-seconds until the speed goes below the setting or the speed setting is increased above
    ; the speed.
    ; When pressing the Up switch at power up, a 'r' on the right display indicates repeat
    ; alarm and a '-' indicates no-repeat alarm option.
    ; Pressing the Mode switch at power up will toggle the speed alarm with the speedometer on or off
    ; If the display shows an 'S' then the speedometer function will operate and a '-' indicates that
    ; the speedometer is off.
    ; Pressing the Down switch at power up will set the speed alarm threshold point either high or
    ; low. The low threshold means that the alarm will sound at the set speed and switch off
    ; when the speed goes 1km/h or less below this speed. The high threshold will set the alarm
    ; when the speed is 1km/h or more above the set speed and go off for speeds at or below the
    ; set speed. A high setting will be indicated by an 'H' and a low setting by an 'L'as shown during
    ; power up with the down switch pressed.
    ; Processor pin allocations are as follows:
    ; RA0 Output disp1 driving transistor for common anode display
    ; RA1 Output disp2
    ; RA2 Output disp3
    ; RA3 Output for alarm
    ; RA4 Input from switches
    ; RB0 Input for wheel sensor (interrupt)
    ; RB1 c segment drive for seven segment LED display
    ; RB2 d segment drive
    ; RB3 e segment drive
    ; RB4 f segment drive
    ; RB5 a segment drive
    ; RB6 b segment drive
    ; RB7 g segment drive
    ; CPU configuration
    	list P=16F84
    	#include "p16f84.inc"
    	__config _XT_OSC & _WDT_OFF & _PWRTE_ON
    ; Define variables at memory locations
    ; EEPROM DATA
    EEPROM1		equ	H'00'	; non-volatile storage for display1
    EEPROM2		equ	H'01'	; non-volatile storage for display2
    EEPROM3		equ	H'02'	; non-volatile storage for display3
    EEPROM4		equ	H'03'	; non-volatile storage to toggle repeat alarm feature and mode
    EEPROM5		equ	H'04'	; non-volatile storage of LS byte of calibration number
    EEPROM6		equ	H'05'	; non-volatile storage of MS byte of calibration number
    ; RAM
    DISP1		equ	H'0C'	; working storage for Display1 value alarm speed mode
    DISP2		equ	H'0D'	; working storage for Display2 value alarm speed mode
    DISP3		equ	H'0E'	; working storage for Display3 value alarm speed mode
    STATUS_TMP 	equ H'0F'	; temp storage for status during interrupt
    W_TMP		equ	H'10'	; temporary storage for w during interrupt
    VALUE_1		equ H'11'	; delay value storage
    VALUE_2		equ	H'12'	; delay value storage
    FLAG_1		equ	H'13'	; flag, bit 0 = flag for closed switch, bit 1 for interrupt indicator
    						; bit 2 for alarm tone required, bit 3 for tone duty cycle,
    						; bit 4 alarm off, bit 5 overspeed, bit 6 EEPROM
    						; write repeat number, bit 7 for calibrate flag
    FLAG_2		equ	H'14'	; alarm tone period settable from 00-FE
    FLAG_3		equ	H'15'	; alarm tone sequence 00000000=on,00000001=off,00000010=on >=00000011 off,
    						; use a more significant bit to set reocurrence, bit 6 or 7
    REPEAT		equ	H'16'	; bit 0 working store repeat alarm flag stored in EEPROM4, bit 1 on/off flag
    						; bit 1 on/off flag, bit 2 speedo/alarm select flag, bit 3 speedo on/off flag
    						; bit 4 alarm threshold
    SPEED_EQV	equ	H'17'	; storage for speed equivalent (value of 5 per 5km/h) 160km/h=160
    TEMP_1		equ	H'18'	; temporary working storage
    TEMP_2		equ	H'19'	; temp storage
    TIME_CNT1	equ	H'1A'	; counter for pulse count period
    TIME_CNT2	equ	H'1B'	; counter for pulse count period
    TIME_CNT3	equ	H'1C'	; working lsb calibration number stored in EEPROM5
    TIME_CNT4	equ	H'1D'	; working msd calibration number stored in EEPROM6
    PULSE_CNT	equ	H'1E'   ; counter for speed pulses compared with speed_eqv
    ERR_FLG		equ	H'1F'	; bit 0 is error flag for counter overrange during calibration
    SPEEDO		equ	H'20'	; latched value for speedometer obtained from PULSE_CNT
    SPEED1		equ	H'21'	; display1 value during speedometer mode
    SPEED2		equ	H'22'	; display2 value during speedometer mode
    SPEED3		equ	H'23'	; display3 value during speedometer mode
    TEMP		equ	H'24'	; temporary register for BCD conversion
    BCD_0		equ	H'25'	; decimal value MSD
    BCD_1		equ	H'26'	; decimal packed BCD LS digits
    BIN_0		equ	H'27'	; binary value for BCD conversion
    CNT_8		equ	H'28'   ; counter for BCD conversion
    TEMP_X		equ	H'29'	; temporary register for speed equivalent calculation
    ; preprogram EEPROM DATA
    	ORG     2100
    	DE	0x00, 0x06, 0x00	; preset EEPROM1-EEPROM3 ( initial speed setting is 60)
    		DE	0x03			; set EEPROM4 (repeat alarm on bit 0 and set to on/off bit 1)
    							; bit 2 speedo/set bit to set alarm mode, bit 3 speedo on
    							; bit 4 alarm threshold low
    		DE	0xB3, 0x11		; set calibration EEPROM5 & EEPROM6 (set to 100Hz = 160km/h
    ; calibration calculated out at 1.6s update time 160km/h = 160 pulses counted.
    ; 3.579545MHz/4/2/(256-100+2) = 353.1175us and require 4531Decimal for 1.6 sec or 11B3Hex
    ; Program begins
    ; define reset and interrupt vector start addresses
    	org	0			  	; start at address 0000h
    	goto	MAIN		; normal service routines from Reset vector
    	org     4			; interrupt vector 0004h, start interrupt routine here
    	goto	INTER		; go to start of interrupt routine, bypass subroutines
    ; subroutine to get seven segment display data. (This is placed at front of programm to prevent computed
    ; goto crossing 256 bit boundary. *PCL control only over least significant 8-bits*)
    	SVNSEG	andlw	0x0F; remove most significant bits if present prevents value >16h
    	addwf	PCL,f		; add value of display to program counter
    	retlw 	B'10000000'	; 7-segment code 0
    	retlw 	B'10111100'	; 7-segment code 1
    	retlw 	B'00010010'	; 7-segment code 2
    	retlw 	B'00011000'	; 7-segment code 3
    	retlw 	B'00101100'	; 7-segment code 4
    	retlw 	B'01001000'	; 7-segment code 5
    	retlw 	B'01000000'	; 7-segment code 6
    	retlw 	B'10011100'	; 7-segment code 7
    	retlw 	B'00000000'	; 7-segment code 8
    	retlw 	B'00001000'	; 7-segment code 9
    - if need be i'll contact the developers website on why their code is ridden with bugs. Thanks for look at it.
    Sep 2007
    Part 2
    ; INTERRUPT
    ; interrupt from counter used to multiplex display
    ; this sucessively switches on Disp1, Disp2, Disp3 in sequence plus
    ; blanking leading zeros on display for Disp2 and Disp3 for either
    ; speedometer or set alarm speed modes
    ; uses internal timer to initiate display update
    ; also updates time period counters which set period of speed pulse counting
    ; checks speed against alarm setting
    ; speed sensor update
    ; start interrupt by saving w and status registers before altered by interrupt routine
    	INTER	movwf	W_TMP	; w to w_tmp storage
    	swapf	STATUS,w		; status to w
    	movwf	STATUS_TMP		; status in status_tmp
    ; which interrupt (INT or TMRO)
    	btfsc	INTCON,T0IF		; TMRO overflow interrupt flag then goto litchk
    	goto	LITCHK			; TMRO overflow so multiplex display
    SENSOR	btfsc	INTCON,INTF	; INT interrupt flag set then goto speed
    	goto	SPEED			; speed sensor signal update
    	goto	RECLAIM			; end of interrupt reclaim w and status
    ; multiplex display routine
    LITCHK	btfsc	REPEAT,1	; check if speed alarm unit on or off
    	goto	ALM_BY			; on so skip resetting alarm (alarm bypass)
    ; reset alarm function
    	clrf	PULSE_CNT	; clear pulse counter so no alarm
    	clrf	TIME_CNT1	; clear time counter 1
    	clrf	TIME_CNT2	; clear time counter 2
    ALM_BY	bcf	STATUS,RP0	; select bank 0
    	movlw	D'100'		; speed up multiplex rate for suitable tone in piezo alarm (100
    						; is used in calibration number calculation and for output freq)
    						; freq is 3.579545MHz/2/4/(256-100+2)/2 = 1.4159kHz
    	addwf	TMR0,f		; add to timer registerand takes 2 cycles to start counting
    	bcf	INTCON,T0IF		; clear TMRO interrupt flag
    	bsf	FLAG_1,0		; indicate another interrupt has occurred
    	btfsc	REPEAT,2	; check if speedometer or alarm speed mode
    	goto 	SPD_LTE		; display update in speedometer mode
    	btfss	PORTA,0		; skip if display 1 not lit
    	goto	LIT1		; display 1 lit
    	btfss	PORTA,1		; skip if display 2 not lit
    	goto	LIT2		; display 2 lit
    	btfss	PORTA,2		; skip if display 3 not lit
    	goto	LIT3		; display 3 lit
    	movlw	B'11111110'	; seven segments off
    	movwf	PORTB
    	bcf	PORTA,2			; no displays lit so set disp3 (used if error in output)
    	goto 	LITCHK		; goto check which is lit now
    LIT1	bsf	PORTA,0		; disp1 off
    	movf	DISP3,w		; look at display3
    	xorlw	0x00		; compare display3 with 0
    	btfss	STATUS,Z	; skip if zero
    	goto	NOBLNK		; do not blank display2
    	movf	DISP2,w		; look at display2
    	xorlw	0x00		; compare disp2 with 0
    	btfss	STATUS,Z	; skip if 0
    	goto	NOBLNK		; do not blank disp2
    	movlw	B'11111110'	; 7-segment display off
    	goto	BLANK		; blank disp2 when disp2 and disp3 = 0
    NOBLNK	movf	DISP2,w		; disp2 to w
    	call 	SVNSEG		; goto subroutine to get seven segment code
    BLANK	btfss	ERR_FLG,0	; calibrate error
    	goto	CAL_M		; mid display
    	movlw	B'10000110'	; set display for 'r' (Err)
    	goto	LIT_r		; light an r
    CAL_M	btfsc	FLAG_1,7	; calibrate flag skip if clear
    	movlw	B'00000100'	; set display to show an A (for CAL)
    	btfss	REPEAT,1	; is speed alarm unit on or off, 1 is on 0 is off
    	movlw	B'01111110'	; set 'g' segment on display
    LIT_r	movwf	PORTB		; seven segment value to portB
    	bcf	PORTA,1		; disp2 powered
    	goto	TIMECNT		; end of multiplex
    LIT2	bsf	PORTA,1		; disp2 off
    	movf	DISP3,w		; disp3 to w
    	xorlw	0x00		; compare with 0
    	goto 	SHOW		; show digit on disp3
    	goto	BLNK		; value to blank display
    SHOW	movf	DISP3,w		; look at display3
    	call	SVNSEG		; get 7-segment value
    BLNK	btfss	ERR_FLG,0	; calibrate error
    	goto	CAL_L		; Left display
    	movlw	B'01000010'	; set display for 'E' (Err)
    	goto	LIT_E		; light an E
    CAL_L	btfsc	FLAG_1,7	; calibrate flag skip if clear
    	movlw	B'11000010'	; set display to show a C (for CAL)
    LIT_E	movwf	PORTB		; portB has seven-segment code
    	bcf	PORTA,2		; disp3 powered
    LIT3	bsf	PORTA,2		; disp3 off
    	movf	DISP1,w		; disp1 to w
    	call	SVNSEG
    	goto	CAL_R		; Right display
    	goto	LIT_rr		; light an r
    CAL_R	btfsc	FLAG_1,7	; calibrate flag skip if clear
    	movlw	B'11100010'	; set display to show an L (for CAL)
    LIT_rr	movwf 	PORTB
    	bcf	PORTA,0		; disp1 powered
    	goto	TIMECNT
    ; display update for speedometer mode
    SPD_LTE btfss	PORTA,0	; skip if display 1 not lit
    	goto	SPD_LT1		; display 1 lit
    	goto	SPD_LT2		; display 2 lit
    	goto	SPD_LT3		; display 3 lit
    	movwf	PORTB
    	goto 	SPD_LTE		; goto check which is lit now
    SPD_LT1	bsf	PORTA,0		; disp1 off
    	movf	SPEED3,w	; look at display3
    	goto	NOBLNK1		; do not blank display2
    	movf	SPEED2,w	; look at display2
    	goto	NOBLNK1		; do not blank disp2
    	goto	BLANK1		; blank disp2 when disp2 and disp3 = 0
    NOBLNK1	movf	SPEED2,w	; disp2 to w
    BLANK1	movwf	PORTB		; seven segment value to portB
    SPD_LT2	bsf	PORTA,1		; disp2 off
    	movf	SPEED3,w	; disp3 to w
    	goto 	SHOW1		; show digit on disp3
    	goto	BLNK1		; value to blank display
    SHOW1	movf	SPEED3,w	; look at display3
    BLNK1	movwf	PORTB		; portB has seven-segment code
    SPD_LT3	bsf	PORTA,2		; disp3 off
    	movf	SPEED1,w	; disp1 to w
    	call	SVNSEG
    	movwf 	PORTB
    ; update time period counters for speed pulse counter
    TIMECNT	btfsc	FLAG_1,7	; calibrate flag skip if clear (no calibrate)
    	goto	CALBRAT		; calibrate switch pressed so do calibration
    	movf	TIME_CNT4,w	; MS Byte of calibration value to w
    	xorwf	TIME_CNT2,w	; compare MS Byte counter with calibration
    	btfss	STATUS,z	; skip if equal
    	goto	INC_CT1		;
    	movf	TIME_CNT3,w	; LS Byte of calibration value
    	xorwf	TIME_CNT1,w	; compare LS byte counter with calibration
    	goto	INC_CT1		;
    	clrf	TIME_CNT1	; clear timer counter 1
    	clrf	TIME_CNT2	; and timer 2
    	movf	PULSE_CNT,w	; look at pulse counter value
    	movwf	SPEEDO		; speedometer value latched pulse counter value
    Sep 2007
    part 3
    ; routine to convert speedo memory to speed 1, 2 & 3 display memory
    	sublw	0xFF		; compare with maximum value (255km/h)
    	btfsc	STATUS,Z	; is it at maximum
    	goto	LIMIT		; maximum of 255 on display
    ; convert speedo to BCD place in Speed 3,Speed 2 and Speed1
    	movf	SPEEDO,w	; look at speedo value
    	movwf	BIN_0		; to binary register
    	call	BCD		; convert to BCD
    	movf	BCD_0,w		; ms digit
    	movwf	SPEED3		; display MSD
    	movf	BCD_1,w		; LS Digits
    	andlw	0x0F		; mask bits 7-4
    	movwf	SPEED1		; ls digit
    	swapf	BCD_1,w		; look at ms nibble
    	andlw	0x0F
    	movwf	SPEED2		; middle digit
    	goto	CK_SPD
    LIMIT	movlw	0x08		; place 8 in speed1-3 memory so display -
    	movwf	SPEED1		; - shows 888 for overrange speedometer
    	movwf	SPEED2
    	movwf	SPEED3
    ; check speed against alarm setting
    CK_SPD	movf	SPEED_EQV,w	; speed equivalent value to w
    	btfsc	REPEAT,4	; skip if alarm threshold low
    	addlw	0x01		; increase speed equiv by hysteresis value
    	subwf	PULSE_CNT,w	; subtract speed equivalent from pulse counter
    	btfsc	STATUS,c	; if positive or zero (c=1) then sound overspeed alarm
    	goto 	SETALM
    ; add hysteresis (addition of 1 to pulse counter gives 1km/h hysteresis)
    	movf	PULSE_CNT,w	; pulse counter value
    	btfss	REPEAT,4	; skip if alarm threshold high
    	addlw	0x01		; increase by factor for hysteresis (on to off alarm speed)
    	movwf	PULSE_CNT
    	movf	SPEED_EQV,w
    	subwf	PULSE_CNT,w	; subtract speed equivalent from new pulse counter value
    	btfsc	STATUS,c	; if positive or zero (c=1) then leave set alarm on
    	goto	ALM_CL		; continue alarm
    	goto	CLRALM		; clear alarm as below overspeed
    INC_CT1 incfsz	TIME_CNT1,f	; increase counter 1 skip if overflowed
    	goto 	ALARM
    	incf	TIME_CNT2,f	; increase counter 2 when counter 1 overflows
    	goto 	ALARM
    ; calibrate time counters
    CALBRAT	incfsz	TIME_CNT1,f	; increase counter 1 skip if overflowed
    	goto	CMP_PLS
    	incfsz	TIME_CNT2,f	; increase counter 2 on overflow skip if overflowed
    	goto	CMP_PLS		; not overrange so compare pulse count with speed equiv
    	bsf	ERR_FLG,0	; error flag set as counter 2 has overranged
    	bcf	FLAG_1,7	; calibrate off flag
    	goto	C_ALM
    CMP_PLS	movf	PULSE_CNT,w	; pulse counter to w
    	xorwf	SPEED_EQV,w	; compare pulse counter with speed equivalent (display value)
    	btfss	STATUS,Z	; skip if equal
    	goto 	C_ALM
    ; store time counters TIME_CNT1 & 2 into TIME_CNT3 & 4 and into EEPROM5 & 6 - new calibration
    	movf	TIME_CNT1,w	; time counter 1 to w
    	movwf	TIME_CNT3	; time counter 3 = 1
    	movf	TIME_CNT2,w	; time counter 2 to w
    	movwf	TIME_CNT4	; time counter 2 = 4
    	bcf	FLAG_1,7	; calibrate flag clear, calibrate off
    ; clear alarm
    CLRALM	clrf	PULSE_CNT	; clear pulse counter for recount
    C_ALM	bcf	FLAG_1,5	; overspeed flag
    	bcf	FLAG_1,4	; clear alarm off flag
    	bsf	PORTA,3		; alarm output high
    	goto	ALARM		; continue program
    ; set alarm
    SETALM	clrf	PULSE_CNT	; clear pulse counter for recount
    	btfsc	FLAG_1,5	; is overspeed flag set. Skip if not
    	goto	ALARM		; set so skip setting alarm again, wait till cleared
    	bsf	FLAG_1,5	; overspeed flag
    	bsf	FLAG_1,2	; set alarm tone flag
    	bsf	FLAG_1,4	; set alarm off flag
    	clrf	FLAG_2		; alarm tone period
    	bcf	FLAG_1,3	; clear on off flag
    	clrf	FLAG_3		; alarm tone sequence
    ; alarm tone routine generates a beep beep tone for over-speed
    ALM_CL	clrf	PULSE_CNT
    ALARM	btfss	FLAG_1,4	; alarm off flag
    	goto	SENSOR		; alarm not required
    	incf	FLAG_2,f	; alarm tone period
    	btfss	FLAG_1,2	; skip if alarm tone required
    	goto	RDFLG_2		; no alarm go to check sensor interrupt
    	btfsc	FLAG_1,3	; alternate on and off flag for tone
    	goto	SET_OUT		; if flag set then stop tone on RA3 output
    	btfsc	PORTA,3		; is alarm out low
    	goto	SET_OUT
    	bsf	PORTA,3		; alarm out pin high
    	goto	CNT_SEQ
    SET_OUT	bcf	PORTA,3		; alarm out pin low
    CNT_SEQ	bcf 	FLAG_1,3
    	btfss	FLAG_3,0	; read alarm tone sequence (bit 0 low then alarm tone)
    	goto	RDFLG_2
    	bsf	FLAG_1,3	; no tone
    	btfss	FLAG_3,1	; check count
    	goto 	RDFLG_2
    	bcf	FLAG_1,2	; alarm off
    	bcf	PORTA,3		; alarm out low
    	goto 	SENSOR
    RDFLG_2	movf	FLAG_2,w	; read alarm tone period counter
    	sublw	0xFE		; alarm tone on-time (FE = max) (00 = min)
    	btfss	STATUS,C	; skip if less than on-time
    	goto	SET_FLG
    	goto 	SENSOR
    SET_FLG incf	FLAG_3,f	; next sequence
    	clrf	FLAG_2		; start period count
    	btfss	FLAG_3,7	; look at bit for repeat tone period, 7 is longest interval, 6 half the period etc
    	goto	SENSOR		; if bit set then repeat alarm
    	btfss	REPEAT,0	; skip if repeat flag set
    	goto	SENSOR
    	bsf	FLAG_1,2	; allow alarm again
    	clrf	FLAG_3		; clear repeat bit
    	goto	SENSOR
    SPEED	bcf	INTCON,INTF	; clear INT flag
    	incfsz	PULSE_CNT,f	; increase pulse counter value for each speed sensor input
    	goto	RECLAIM
    	movlw	0xFF		; max value
    	movwf	PULSE_CNT	; place max count in pulse counter do not allow overrange
    RECLAIM	swapf	STATUS_TMP,w	; status temp storage to w
    	movwf	STATUS		; w to status register
    	swapf	W_TMP,f		; swap upper and lower 4-bits in w_tmp
    	swapf   W_TMP,w		; swap bits and into w register
    	retfie			; return from interrupt
    Sep 2007
    Default part 4
    ; RESET
    ; Set ports A & B
    MAIN	clrf	FLAG_1		; clear flag memory
    	clrf	ERR_FLG		; clear error flag used in calibration
    	clrf	TIME_CNT1	; clear time period counter for speed pulse update
    	clrf	TIME_CNT2	; clear time period counter
    	clrf	PULSE_CNT	; clear speed pulse counter
    	clrf	SPEED1		; clear speedometer display1
    	clrf	SPEED2		; clear speedometer display2
    	clrf	SPEED3		; clear speedometer display3
    	bsf	STATUS,RP0	; select memory bank 1
    	movlw	B'00000001'	; w = 00000001 binary (RB0 input, RB1-RB7 output)
    	movwf	TRISB		; port B data direction register
    	movlw	B'10000000'	; w = 10000000 binary
    	movwf	OPTION_REG	; TMRO prescaler no division, PORTB pullups disabled
    	movlw   B'00010000'	; w = 10000 binary (RA0-RA2, RA3 outputs, RA4 input)
    	movwf   TRISA		; A port data direction register
    	bcf	STATUS,RP0	; select memory bank 0
    	movlw	B'11111110'	; w is all 1's for RB7-RB1, 0 for RB0
    	movwf	PORTB		; portB outputs high
    	movlw	B'00001111'
    	movwf	PORTA		; portA RA0 high, RA1,RA2 outputs high, RA3 high
    ; get memory in EEPROM1, EEPROM2 & EEPROM3 for speed setting, place in DISP1, DISP2, DISP3
    	movlw	EEPROM1		; address for EEPROM1
    	call	EEREAD		; read EEPROM storage
    	sublw	0x09		; compare with 9
    	btfss	STATUS,C	; skip if positive therefore a 9 or less
    	goto	CLR1		; greater than 9 then clear to 0
    	movf	EEDATA,w	; restore w
    	movwf	DISP1		; EEPROM1 to DISP1
    	goto	EEPRM2
    CLR1	clrf	DISP1		; Disp1 = 0 as disp1 was more than 9 (illegal value)
    EEPRM2	movlw	EEPROM2		; address for EEPROM2
    	call	EEREAD
    	goto	CLR2
    	movwf	DISP2		; EEPROM2 to DISP2
    	goto	EEPRM3
    CLR2	clrf	DISP2		; disp2 = 0 as disp2 was more than 9 (illegal value)
    EEPRM3	movlw	EEPROM3		; address for EEPROM3
    	call	EEREAD
    	sublw	0x01		; compare with 1
    	btfss	STATUS,C	; skip if positive therefore a 1 or less
    	goto	CLR3
    	movwf	DISP3		; EEPROM3 to DISP3
    	goto	EEPRM5
    CLR3	clrf	DISP3		; disp3 = 0 as disp3 was more than 1 (illegal value)
    ; get EEPROM5 and EEPROM6 calibration values and place in TIME_CNT3 and TIME_CNT4
    EEPRM5	movlw	EEPROM5		; address for EEPROM5
    	call	EEREAD
    	movwf	TIME_CNT3	; store in LS byte calibration register
    	movlw	EEPROM6		; address for EEPROM6
    	call	EEREAD
    	movwf	TIME_CNT4	; store in MS byte calibration register
    ; get memory EEPROM4 and place in REPEAT. This is the indicator for
    ; repeat alarm on or off, bit 0. ON/OFF flag, bit 1, bit 2 is speedo, bit 3 is speedo on/off
    ; bit 4 is alarm threshold high or low
    EEPRM4	movlw	EEPROM4		; address for EEPROM4
    	call	EEREAD
    	movwf	REPEAT		; store in repeat register
    ; check for pressed up switch
    	bcf	PORTA,2		; clear RA2 to check if up switch pressed
    	nop
    	nop			; allow time for levels to settle
    	btfsc	PORTA,4		; is up switch pressed
    	goto	CHK_DN		; switch open so check down switch
    	btfsc	REPEAT,0	; test for repeat flag bit 0
    	goto	CLRREP		; clear repeat off alarm
    	bsf	REPEAT,0	; set repeat for alarm
    	movlw	B'10000110'	; 'r' on display for repeat alarm
    	goto	SWOPEN
    CLRREP	bcf	REPEAT,0	; clear repeat
    	movlw	B'01111110'	; '-' on display for no repeat alarm
    SWOPEN	movwf	TEMP_1
    SWCLSD	bsf	PORTA,0		; display off
    	bsf	PORTB,5		; clear a segment
    	bsf	PORTB,6		; clear b segment
    	bsf	PORTB,3		; e segment
    	bsf	PORTB,4		; f segment
    	bsf	PORTB,7		; g segment
    	bsf	PORTB,2		; clear display at RB
    	call	DELMO
    	btfsc	PORTA,4		; wait for switch to open
    	goto	MODESTO		; store repeat setting when switch opens
    ; multiplex display until switch opens
    	bsf	PORTA,2		; RA2 high
    	nop
    	nop
    	nop
    	bcf	PORTA,0		; RA0 low so display 1 lit
    	movf	TEMP_1,w	; retrieve temp storage value
    	movwf	PORTB		; port B a-g segments on again
    	call	DELMO		; more delay time
    	goto 	SWCLSD		; check for pressed switch
    ; check for pressed down switch
    CHK_DN	bsf	PORTA,2		; RA2 high so Disp3 will be off
    	bsf	PORTA,0		; RA0 high so disp1 off
    	nop
    	nop
    	bcf	PORTA,1		; clear RA1 to check if down switch pressed
    	nop
    	btfsc	PORTA,4		; is down switch pressed
    	goto	CHK_MDE		; switch open so check mode switch
    	btfsc	REPEAT,4	; test for threshold flag bit 4
    	goto	CLRTRS		; clear threshold flag bit
    	bsf	REPEAT,4	; set threshold high
    	movlw	B'00100100'	; 'H' on display for high threshold
    	goto	DNOPEN
    CLRTRS	bcf	REPEAT,4	; clear threshold flag
    	movlw	B'11100010'	; 'L' on display for low threshold
    DNOPEN	movwf	TEMP_1
    DNCLSD  bsf	PORTB,6		; clear b segment
    	bsf	PORTB,1		; clear c segment
    	bsf	PORTB,2		; d segment
    	call	DELMO		; more delay time (multiplex)
    	movf	TEMP_1,w
    	goto 	DNCLSD		; check for pressed switch
    Sep 2007
    Default part 5
    ; check for pressed Mode switch
    CHK_MDE	bsf	PORTA,1		; RA1 high so disp2 off
    	bsf	PORTA,2		; RA2 high so disp3 off
    	nop
    	nop
    	bcf	PORTA,0		; clear RA0 to check if mode switch pressed
    	nop
    	nop
    	btfsc	PORTA,4		; is mode switch pressed
    	goto	NO_OPEN		; switch open so no change
    	btfss	REPEAT,3	; test for speedo on/off flag bit 3
    	goto	CLRSPED		; clear speedo on/off
    	bcf	REPEAT,3	; set speedo
    	movlw	B'01001000'	; 's' on display for speedo
    	movwf	TEMP_1
    	goto	MODEOPN
    CLRSPED	bsf	REPEAT,3	; set speedo on/off flag
    	movlw	B'01111110'	; '-' on display for no speedo
    	movwf	TEMP_1
    	bcf	REPEAT,2	; clear speedometer flag
    MODEOPN	bsf	PORTA,2		; display off
    	call	DELMO		; more delay time (multiplex time)
    	nop
    	nop
    	nop
    	bcf	PORTA,2		; RA2 low so display 1 lit
    	movf	TEMP_1,w
    	movwf	PORTB		;
    	goto 	MODEOPN
    ; delay period for multiplex rate
    DELMO	movlw 	D'255'		; delay period
    	movwf	TEMP_2
    SMALR	decfsz	TEMP_2,f	; reduce temp_2
    	goto	SMALR		; temp_2 smaller by 1
    	return			; end delay
    ; write new mode option to EEPROM4
    MODESTO	movlw	EEPROM4		; address for EEPROM4
    	movwf	EEADR		; address for write
    	movf	REPEAT,w	; flag stored
    	call	EWRITE		; write to EEPROM
    ; calculate speed equivalent value
    NO_OPEN	call	SPDEQIV		; calculate speed equivalent
    	goto	INT_SET
    ; subroutine to read EEPROM memory
    EEREAD	movwf 	EEADR		; indirect special function register
    	bsf	EECON1,RD	; read EEPROM
    RD_RD	nop
    	btfsc	EECON1,RD	; skip if RD low (read complete)
    	goto 	RD_RD		; wait for low RD (read RD)
    	movf	EEDATA,w	; EEPROM value in w
    ; subroutine to calculate speed equivalent of 8 per 5km/h this value is compared with
    ; counted pulses from speed sensor.
    SPDEQIV	bcf	FLAG_1,5	; overspeed flag
    	clrf	SPEED_EQV	; clear speed equivalent store
    ; Convert the display readings to a binary speed equivalent value
    	movf	DISP3,w		; look at DISP3 value
    	btfsc	STATUS,z	; check if 0
    	goto 	ZERO
    	xorlw	0x01		; check if a 1
    	btfsc	STATUS,z	; z is 1 if a 1
    	goto	ONE		;
    	movlw	D'100'		; 100
    	movwf	SPEED_EQV	; 100 in speed equivalent
    ONE	movlw	D'100'
    	addwf	SPEED_EQV,f	; 200 if disp3 was a 2
    ZERO	movf	DISP2,w		; look at display 2
    	movwf	TEMP_X		; place in temporary register
    INC_SE	movlw	D'10'		; 10
    	addwf	SPEED_EQV,f	; increase speed equivalent by 10
    	decfsz	TEMP_X,f	; reduce disp2 value
    	goto	INC_SE		; do again
    	movf	DISP1,w		; display 1 value
    	addwf	SPEED_EQV,f	; add display 1 value
    ; allow interrupts
    INT_SET	btfss	REPEAT,1	; bit 1 on/off flag
    	goto	RB0_INT		; no RB0 interrupt if speed alarm unit in off mode
    	bsf	INTCON,INTE	; set interrupt enable for RB0
    RB0_INT	bsf	INTCON,T0IE	; set interrupt enable for TMR0
    SWITCH	bsf	INTCON,GIE	; set global interrupt enable for above
    ; check if a switch is pressed
    	bcf	FLAG_1,0	; clear multiplex update flag
    MULTIP	btfss	FLAG_1,0	; check if multiplex update occured
    	goto	MULTIP		; wait for new multiplex update for display
    	btfsc	PORTA,4		; if a switch is pressed, then bit 4 will be low
    	goto	SWITCH		; no switch pressed so look again
    ; check for Cal switch
    	bcf	INTCON,GIE	; clear interrupts
    	bcf	ERR_FLG,0	; clear error flag when any switch pressed
    	movf	PORTA,w		; look at RA0-RA2
    	movwf	TEMP_1		; store in temporary memory
    	iorlw	B'00000111'	; bit 0-2 high
    	movwf	PORTA		; place in port A, displays off
    	movlw	0x1F		; delay period
    	movwf	VALUE_1		; VALUE_1 = w
    DELOOP	decfsz	VALUE_1,f	; decrease VALUE_1, skip if zero
    	goto	DELOOP
    	btfss	PORTA,4		; is the cal switch pressed
    	goto 	CALIBRT		; yes it is the cal switch
    	movf	TEMP_1,w	; retrieve port A bit 0-2
    	movwf	PORTA		; port A bits 0-2 as before
    	nop			; give time for ports to change
    	nop
    	nop
    	btfsc	PORTA,0		; is it the mode switch
    	goto	D_U_CHK
    	goto 	MODE
    D_U_CHK	btfss	REPEAT,1	; is on/off flag on
    	goto	WAIT		; no up down selection allowed when speed alarm unit is off
    	btfsc	PORTA,1		; is it the Down switch
    	goto	U_CHK
    	goto	DOWN
    U_CHK	btfsc	PORTA,2		; is it the UP switch
    	goto	SWITCH		; no switch reading
    	goto 	UP
    Sep 2007
    Default part 6
    MODE	btfss	REPEAT,1	; bit 1 a '1' for on (on/off flag)
    	goto	SET_1		; was off so turn on
    	btfsc	REPEAT,3	; speedo on/off flag
    	goto	BYSPD
    	btfss	REPEAT,2	; speedometer or alarm set mode
    	goto	SET_2		; repeat1 status same, repeat2 =1
    BYSPD	bcf	REPEAT,1	; if set then clear on/off flag
    	bcf	INTCON,INTE	; clear interrupt enable for RB0
    	goto 	WAIT
    SET_2	bsf	REPEAT,2	; set speedometer flag
    	goto	NO_SET1
    SET_1	bsf	REPEAT,1	; if clear then set on/off flag
    NO_SET1	bsf	INTCON,INTE	; set interrupt enable for RB0
    	goto	WAIT
    UP	movf	DISP1,w		; display1 to w register
    	xorlw  	0x05		; compare with decimal'5'
    	btfss	STATUS,Z	; skip next instruction if Disp <9 decimal
    	goto	UP_1		; increase display1
    ; check for maximum on display
    	xorlw	0x05		; compare with a 5
    	btfss	STATUS,Z	; is it 5 then check DISP3
    	goto	DISP_UP
    	movf	DISP3,w		; look at disp3
    	xorlw	0x02		; compare with a 1
    	btfsc	STATUS,Z	; is it a 2
    	goto	WAIT		; maximum of 255 on display so stop counting up
    ; digit overflow
    DISP_UP	clrf	DISP1		; Disp value cleared as it was beyond BCD range (0-9)
    	movf	DISP2,w		; display2 value to w
    	xorlw	0x09		; compare with decimal'9' (H'9')
    	goto	UP_2		; increase display2
    	clrf	DISP2		; Disp value cleared as it was beyond BCD range (0-9)
    	goto 	UP_3		; increase display3
    UP_1	movlw	0x05		; a 5 in the display (count by 5's)
    	movwf	DISP1		; display1 increased
    	goto	WAIT
    UP_2	incf	DISP2,f		; display2 increased
    	goto	WAIT
    UP_3	incf	DISP3,f		; display3 increased
    	goto	WAIT
    DOWN	movf	DISP1,w		; display1 to w register
    	xorlw	0x00		; compare with decimal'0' to see if was zero
    	btfss	STATUS,Z	; skip next instruction if Disp 0 decimal
    	goto	DN_1		; decrease display1
    ; check for display minimum
    	btfss	STATUS,Z	;
    	goto	DISP_DN		; not 0 so can count down
    	movf	DISP3,w		; look at display 3
    	btfsc	STATUS,Z
    	goto 	WAIT		; do not decrease beyond 000
    DISP_DN	movlw	H'05'		; place a 5 in display1
    	movwf	DISP1		; disp1 = 5
    	xorlw	0x00		; compare with decimal'0' to see if 0
    	goto	DN_2		; decrease display2
    	movlw	H'09'		; Disp value = 9
    	movwf	DISP2
    	goto 	DN_3		; decrease display3
    DN_1	clrf	DISP1		; display1 decreased to 0
    	goto	WAIT
    DN_2	decf	DISP2,f		; display2 decreased
    	goto	WAIT
    DN_3	decf	DISP3,f		; display3 decreased
    ; wait period (delay plus EEPROM write time)
    ; delay loop plus apply tone to piezo alarm as switch press acknowledgement
    WAIT	bsf	INTCON,GIE	; allow global interrupts
    	movlw	D'100'		; set delay period for repeat of value 2 delay (sets key
    				; acknowledge tone frequency)
    	movlw	D'50'		; set delay period value 2 (also sets key acknowledge tone period)
    LOOP_1	movwf	VALUE_2		; VALUE_2 = w
    LOOP_2	decfsz	VALUE_2,f	; decrease VALUE_2, skip if zero
    	goto 	LOOP_2
    	btfsc	PORTA,3		; alarm output check if high or low
    	goto	CLR_T
    	bsf	PORTA,3		; alarm out high
    DEC_V1	decfsz	VALUE_1,f	; decrease VALUE_1, skip if zero
    	goto	LOOP_1
    	goto 	DELTME		; delay time
    CLR_T	bcf	PORTA,3		; alarm out low
    	goto	DEC_V1
    ; more delay time
    DELTME	movlw	D'50'		; set delay period
    	movlw	D'255'		; set delay period value 2
    LP_1	movwf	VALUE_2		; VALUE_2 = w
    LP_2	decfsz	VALUE_2,f	; decrease VALUE_2, skip if zero
    	goto 	LP_2
    	goto	LP_1
    ; EEPROM write. Store new display values in EEPROM
    EPWRT	movlw	EEPROM1		; address for EEPROM1
    	movwf	EEADR		; address to write
    	movf	DISP1,w		; display1 data to w
    	call 	EWRITE		; EEPROM write sequence
    	movf	DISP2,w
    	call	EWRITE
    	movf	DISP3,w
    	call	EWRITE
    	movwf	EEADR		; address to write to
    	movf	REPEAT,w	; repeat values (bit 0 is alarm repeat, bit 1 is on/off)
    	call 	EWRITE
    ; when a new speed setting is selected recalculate speed equivalent value
    	bcf	INTCON,GIE	; disable interrupts
    	call	SPDEQIV		; recalculate speed equivalent value
    	bsf	INTCON,GIE	; enable interrupts
    	goto	CLOSED		; out from EEPROM write
    ; subroutine to write to EEPROM
    EWRITE	bcf	FLAG_1,6	; EEPROM write repeat flag
    	movwf	TEMP_2		; store w in temporary storage
    EWRIT	movf	TEMP_2,w	; place value in w (used for read data sequence)
    	movwf	EEDATA		; data register
    	bsf	STATUS,RP0	; select bank 1
    	bsf	EECON1,WREN	; enable write
    	movlw	0x55		; place 55H in w for write sequence
    	movwf 	EECON2 		; write 55H to EECON2
    	movlw 	0xAA		; AAH to w
    	movwf	EECON2		; write AA to EECON2
    	bsf	EECON1,WR	; set WR bit and begin write sequence
    	bcf	EECON1,WREN	; clear WREN bit
    WRITE	btfsc	EECON1,WR	; skip if write complete WR=0 when write complete
    	goto 	WRITE		; not written yet
    	bcf	EECON1,EEIF	; clear write interrupt flag
    ; read EEPROM DATA and check if written correctly
    RD_AGN	nop
    	goto 	RD_AGN		; wait for low RD
    	subwf	EEDATA,w	; compare read value with value stored
    	btfsc	STATUS,z	; skip if not the same
    	return			; value correctly written
    	btfsc	FLAG_1,6	; write repeat bit, skip if clear and rewrite
    	bsf	FLAG_1,6	; set repeat flag rewrite once only
    	goto 	EWRIT		; rewrite as not written correctly
    ; wait for switch to open (must test for closed switch when RA0, RA1 and RA2 are low
    ; because switch will appear open at RA4 when switch pull down via RA0-RA2 is high)
    CLOSED	bcf	FLAG_1,1	; clear flag that indicates switch closed
    	call	ON		; check for closed switch
    	call	ON		; do three times to return to original switch closure
    	call	ON		;
    	call	ON 		; do again just in case missed an interrupt during call
    	call	ON 		; do again just in case missed one interrupt during call
    	btfsc	FLAG_1,1	; was switch closed
    	goto 	CLOSED		; yes go to check again
    	goto 	SWITCH		; switch open so out
    ; subroutine to wait for switch to reopen
    ON	bcf	INTCON,T0IE	; prevent multiplex update
    	bcf	FLAG_1,0	; clear flag that indicates update interrupt for display
    RE_CHK	btfsc	PORTA,4		; check if switch closed
    	goto	OPEN
    	bsf	FLAG_1,1	; switch closed so set flag
    	bsf	INTCON,T0IE	; allow multiplex interrupt
    	goto	RE_CHK 		; closed so check till open
    OPEN	bcf	FLAG_1,0	; clear multiplex update flag wait for next multiplex update
    	bsf 	INTCON,T0IE	; allow multiplex update
    FLG_TST	btfss	FLAG_1,0	; is flag set indicating a new interrupt for multiplexing
    	goto 	FLG_TST		; wait
    ; calibrate routine
    CALIBRT	btfss	REPEAT,1	; is on/off flag on
    	goto	WAIT		; no calibration allowed when speed alarm unit is off
    	btfsc	REPEAT,2	; is speedometer on
    	goto	WAIT		; no calibration if speedometer mode
    	bsf	FLAG_1,7	; calibrate flag set
    	bcf	INTCON,T0IF	; clear timer interrupt flag
    	bcf	INTCON,INTF	; clear interrupt flag
    	bsf	INTCON,GIE	; allow interrupts
    FLG1_CK	btfsc	FLAG_1,7	; wait for end of calibrate, skip if end
    	goto	FLG1_CK		; recheck flag 1 bit 7 (cleared at end of calibration)
    ; store new calibration count numbers in EEPROM
    	movf	TIME_CNT3,w	; counter 3 to w
    	movf	TIME_CNT4,w	; counter 4 to w
    	goto	SWITCH		; check for a new closed switch
    ; Subroutine to convert from 8-bit binary to 2-digit BCD (packed)
    ; Binary value is in BIN_0
    ; Result in BCD is in BCD_0 & BCD_1.
    ; BCD_0 is MSB, BCD_1 is LSB
    BCD	bcf	STATUS,c	; clear carry bit
    	movlw	D'8'
    	movwf	CNT_8		; 8 in count
    	clrf	BCD_0
    	clrf	BCD_1		; set BCD registers to 0
    LOOPBCD	rlf	BIN_0,f		; shift left binary registers
    	rlf	BCD_1,f		; MSB shift left
    	rlf	BCD_0,f		; LSB shift left BCD registers
    	decfsz	CNT_8,f		; reduce count value return when 0
    	goto	DECADJ		; continue decimal adjust
    	return			; completed decimal to BCD operation
    ; subroutine decimal adjust
    DECADJ	movlw	BCD_1		; BCD LSB address
    	movwf	FSR		; pointer for BCD1
    	call	ADJBCD		; subroutine to adjust BCD
    	movlw	BCD_0		; BCD MS address
    	movwf	FSR		; pointer for BCD0
    	call	ADJBCD
    	goto	LOOPBCD
    ; subroutine adjust BCD
    ADJBCD	movlw	0x03		; w has 03
    	addwf	INDF,w		; add 03 to BCDx register (x is 0-1)
    	movwf	TEMP		; store w
    	btfsc	TEMP,3		; test if >7
    	movwf	INDF		; save as LS digit
    	movlw	0x30		; 3 for MSbyte
    	addwf	INDF,w		; add 30 to BCDx register
    	movwf	TEMP		; store w in temp
    	btfsc	TEMP,7		; test if >7
    	movwf	INDF		; save as MS digit
    	return			; end subroutine
    I'm not saying that you won't get any help but since this is a forum for PicBasic you MAY not get the help you're looking for. Something like the PICList may be more suitable if you're "writing" in, or having problems with ASM.
    BUT, with that being said, have you selected 16F84 in MPLAB? Configure/Select Device and then point to 16F84.
    /Henrik Olsson.
    Feb 2003
    as a starters,
    change commands that look like this (with c or z in them)
    to this
    	btfsc	STATUS,Z	; check if 0
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Sep 2007
    Default thanks guys
    Thanks for the help so far - i'll check out piclist and make the above corrections.
    Sep 2007
    Default Thanks for the tips so far
    btw - I got a build succeeded confirmation - however I have the following error messages.
    Clean: Done.
    Message[302] C:\PIC LAB\SPEED254.ASM 542 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 544 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 546 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 770 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 773 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1049 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1051 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1053 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1054 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1056 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1058 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1060 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1065 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Message[302] C:\PIC LAB\SPEED254.ASM 1068 : Register in operand not in bank 0.  Ensure that bank bits are correct.
    Loaded C:\PIC LAB\SPEED254.cod.
    BUILD SUCCEEDED: Wed Sep 26 07:47:42 2007
    it seems like the error occurs when accessing eeproms or clearing flags
    Does anyone know how to rectify a "Register in operand not in bank 0" error/warning?
    As long as you're sure you did the BANK switching manually, there's no real problem. Unless you may spread some BANKSEL here and there... not sure enough it will solve the warning message so far
    BANKSEL is a nice MPASM tool, it avoid to do the bankswitching yourself AND manually. Same thing as CHK?RP do with PBP. NO YOU DON'T WANT TO USE BANKSEL WITH PBP unless you know some tricks. Even if you know them... i don't find any advantage myself. Maybe Darrel could confirm or contradict it.
    Assuming you already did it (as it seems to be), you just need to disable the warning message with the following
    errorlevel -302
    HTH
    Sep 2007
    well as long as they're only warnings i'll move on to adding to the design.
    thanks
