Am I heading in the right direction?
Results 1 to 8 of 8
    Code is working the way it is written. Your IF THEN loops basicly check to see if logic 0 is detected, if so it checks the next switch and if good continues . . . , it then executes a GOTO main and never goes to the next subroutine. it goes to the subroutine Continue if the if then is false, which as shown is an empty subroutine. The MAIN loop reinitializes the LEDs as off and sets the internal registers as logic high.
    I think you only want to execute the code listed as main at startup. I would use gosub to execute the subroutines and return in the subroutine to cause the code to RETURN to the place just after it was sent there. something like:<p>
    ' code initialization
    led1 = 0 'Turn LED1 off
    led2 = 0 'Turn LED2 off
    led3 = 0 'Turn LED3 off
    led4 = 0 'Turn LED4 off
    pswitch1 = 1 'Define switch1 as not pressed
    pswitch2 = 1 'Define switch2 as not pressed
    pswitch3 = 1 'Define switch3 as not pressed
    pswitch4 = 1 'Define switch4 as not pressed
    ' here is your main loop
    gosub nothing ' check this sub routine and then gosub to the next sub r...
    gosub LEDtwo ' this is the next thing loop will check
    gosub LEDfour ' and then it will heck here
    goto main ' now the loop repeats
    nothing:
    BLA BLA BLA
    LEDtwo:
    MORE BLA BLA
    YAGETTHEIDEA:
    bla bla
    HTH
    JS
    Jul 2007
    Maryland, USA
    Default Not clear?
    I dont think my orginal explanation of this project was clear enough.
    Digits come at intervals of 30 seconds. Total digits per input = 1. Total inputs per code = 4 So I need to scan for 2 minutes, then once I have all four digits, I need to send an output based on the input received.
    Look for input1 for 30seconds = TS1
    Look for input2 for 30seconds = TS2
    Look for input3 for 30seconds = TS3
    Look for input4 for 30seconds = TS4
    so if I get a 1 as my first input, then the other 3 inputs dont matter, LED1 lights up.
    If my first input is a 2 but the other inputs are all zero's, then no LED's light up
    If my first input is a 2 and any other input is 1-4, then LED2 + LED1 light up
    my examples of the first inputs being 2 correspond with the first inputs being 3 or 4 aswell.
    Example of 5 different codes received and their output operation:
    ts1---ts2---ts3---ts4
    1-----0-----1-----0---= HIGH LED1
    2-----0-----0-----0---= NO LED'S HIGH
    2-----1-----0-----0---= HIGH LED1 and LED2
    3-----0-----0-----0---= NO LED'S HIGH
    3-----0-----2-----0---= HIGH LED1 and LED3
    hopefully this will help clarify the operation. i've changed my code a bit, I "think" its starting to get to where it needs to be, but I still dont know how to assign 30seconds per input received.
    'Code Development / Debug Device Setting
    '           DCBA9876543210
    @  DEVICE  11111101110100b           ; Internal Osc, WDT, PWRT, BOD, MCLR reset, CCP w/ RB2, LVprog disabled,
                                         ; Flash program memory write enabled, No Code Prot., No EEPROM Prot.
                                         ; Fail-safe clock monitor enabled, Internal external switch over enabled.
    '------( Symbols/ Labels )------
    Symbol Pswitch1 = portb.0                'Pin6/RB0 is assigned as switch1
    Symbol Pswitch2 = portb.1                'Pin7/RB1 is assigned as switch2
    Symbol Pswitch3 = portb.2                'Pin8/RB2 is assigned as switch3
    Symbol Pswitch4 = portb.3                'Pin9/RB3 is assigned as switch4
    Symbol LED1 = portb.7                 'Pin13/RB7 is assigned as LED1
    Symbol LED2 = portb.6                 'Pin12/RB6 is assigned as LED2
    Symbol LED3 = portb.5                 'Pin11/RB5 is assigned as LED3
    Symbol LED4 = portb.4                 'Pin10/RB4 is assigned as LED4
    '------( Constants )------
    '------( Defines  )------
        Define OSC          8               'Set oscillator at 8MHz
    '------( Variables )------
    GotInfo     var byte
    GotInfo1    var byte
    GotInfo2    var byte
    GotInfo3    var byte
    empty       var byte                         'Time variable not used
    tS1         var byte                         'Time variable for 1st digit
    tS2         var byte                         'Time Variable for 2nd digit
    tS3         var byte                         'Time Variable for 3rd digit
    tS4         var byte                         'Time Variable for 3th digit
    '------( Registers )------
    '            76543210
        OSCCON = %01110110                   'Set Osc for 8Mhz
        TRISB  = %00001111                   'RB0-RB3 = inputs, RB4-RB7 = outputs
        TRISA  = %00000000                   'RA0-RA7 = outputs
        PORTA  = %00000000                   'Turn off portA
        CMCON  = %00000111                   'Turn comparators OFF
        ANSEL  = %00000000                   'A/D converter set as Digital I/0
    '------( Disable Interrupts/Registers )------
    '                  76543210
        INTCON      = %00000000
        PIE1        = %00000000
        PIR1        = %00000000
        OPTION_REG  = %00000000
    '------( Initialization )------
        goto inputloop
    '------( Main Code )------
    Inputloop:                      'Wait here for input
        if pswitch1 = 0 then        'If switch1 is pressed
            led1 = 1                'Light LED1
            pause 3000              'Pause 3 seconds
            goto inputloop          'check for more inputs
        if pswitch2 = 0 then                                            'If Switch2 is pressed
            tS1 = gotinfo                                               'rename Switch2, tS1
                while ts1 = gotinfo                                     '
                        ts2 = Gotinfo1
                        ts2 = empty
                            if pswitch3 = 0 then
                                ts2 = gotinfo1
                                ts2 = empty
                                    if pswitch4 = 0 then
                                        ts2 = gotinfo1
                                        ts2 = empty
                                            if ts2 = empty then
                                                goto checkTs3
                wend
    checkTS3:
        while ts1 = gotinfo and ts2 = empty
                ts3 = gotinfo2
                ts3 = empty
                        ts3 = gotinfo2
                        ts3 = empty
                                ts3 = gotinfo2
                                ts3 = empty
                                if ts3 = empty then
                                    goto checkts4
        wend
    checkTS4:
        WHILE TS1 = gotinfo and ts2 = empty and ts3 = empty
                ts4 = gotinfo3
                ts4 = empty
                        ts4 = gotinfo3
                        ts4 = empty
                                ts4 = gotinfo3
                                ts4 = empty
                                if ts4 = empty then
                                    goto nothing
        wend
        if ts1 = gotinfo then
            led1 = 0
            led2 = 0
            led3 = 0
            led4 = 0
            goto inputloop
        if ts1 = gotinfo and ts2 = gotinfo1 then
            led2 = 1
            led1 = 1
            pause 3000
            led2 = 0
            led1 = 0
            goto inputloop
        if ts1 = gotinfo and ts3 = gotinfo2 then
            led2 = 1
            led1 = 1
            pause 3000
            led2 = 0
            led1 = 0
            goto inputloop
        if ts1 = gotinfo and ts4 = gotinfo3 then
            led2 = 1
            led1 = 1
            pause 3000
            led2 = 0
            led1 = 0
            goto inputloop
    Hi James,
    try this for your config setting instead of the @ devise xxx you have, and use the osccon settings below to set osc speed, just remove the comment for the one you need. MPASM assembler settings
    @ __config _CONFIG1, _INTRC_IO & _WDT_ON & _LVP_OFF & _CP_OFF
    ' for 8mhz
    'OSCCON=%01111000
    'for 4MHZ
    'OSCCON=%01101000
    You might give this a try too:
    If PortB != %00001111 then PAUSE 30000 ' pause 30 seconds
    JS
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Math help - rolling average Wind Direction
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2009, 01:08
  3. How to detect sound direction?
    Last Post: - 13th December 2008, 05:53
  4. Replies: 10
    Last Post: - 8th April 2008, 22:07
  5. Replies: 5
    Last Post: - 12th September 2007, 16:59
