Touch Sensor
Results 1 to 3 of 3
Thread: Touch Sensor
    Default Capacitive Touch Sensor
    I have found a very good Device B6TS-04LT,is a 4 Ch Sensor from OMRON.
    http://docs-europe.electrocomponents...6b8095df92.pdf
    I dont' know how I can put Photos on this Thread :-)
    I Build the Sensor Device with a PIC 16F870 all Work Fine,my only Problem is that when I Read something for Example the Device ID (Work just in Setup Mode),sometime i Receive the Right ID sometime just FFFF and so on,I can not Read any other Value I try all Mode and Routines.
    I use for Write this:
    Include "modedefs.bas" ' Mode definitions for Serout
    Define OSC 4
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 25 ' 9600 Bauds
    DEFINE HSER_CLROERR 1
    ' PortB.4 is Data (Duplex)
    ' PortB.3 is Clock
    'SCS is Chip select
    '''''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''Write to Register'''''''''''''''''''''''''''''''''''''''''' '''''''''
    Low PortB.2 ' SCS
    pauseus 10
    Shiftout PortB.4,PortB.3,5,[Command.highbyte,Dummy,DatenTX.highbyte,DatenTX.lo wbyte] 'Toggle
    pauseus 10
    High PortB.2
    Sound Summer ,[124,10]
    Pause 1000
    '''''''''''''''''''''''''''''''''''''''''''''''''' ''''''''''Write to EEPROM'''''''''''''''''''''''''''''''''''''''''''' ''''''
    Command.highbyte = %10111111 'Write EEPROM
    Command.lowbyte = %00000000
    DatenTX.highbyte = %01010011
    DatenTX.lowbyte = %01010100
    Dummy = $FF
    Low PortB.2
    pauseus 10
    pauseus 10
    High PortB.2
    Pause 1000
    This Work fine !
    '''''''''''''''''''''''''''''''''''''''''''''''''' ''''''Read ID'''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''
    Command.highbyte = %00000000
    DatenRX.highbyte = $00
    DatenRX.lowbyte = $00
    Dummy = $FF
    Low PortB.2 'SCS
    pauseus 10
    Shiftin PortB.4,PortB.3,6,[Command.highbyte,Dummy,DatenRx.Highbyte,DatenRx.Lo wbyte]
    pauseus 10
    High PortB.2 ' SCS
    This Code dont' Work all the Time,when I use any other Command I Receive just the ID und not the right Value what I need.
    My second question :-) is why I need SCS what is SCS(Chip select).
    I try Hours and Hours to find the way but no Result.
    Thank you for any answer !
    Regards Pesti.
    Ok I now understand what Chip Select is !
    But this dont Help me to find what the Problem is.
    Regards Pesti.
    I dont have try enough,I have now the solution .
    Maybe some one have the same Problem !
    For example:
    ReadID:
    DatenRX = 0
    Low PortB.2 'Chip Select
    Pauseus 1
    Shiftout PortB.4,PortB.3,5,[Command.highbyte,Dummy] 'Send Command Byte
    Pauseus 130 'Wait
    Shiftin PortB.4,PortB.3,6,[DatenRX.highbyte,DatenRX.lowbyte] 'Receive Data from Slave
    Pauseus 1
    High PortB.2 'Chip Select
    Pause 100
    Hserout ["Command = ",DEC Command.lowbyte,",","Chip ID = ",HEX2 DatenRX.highbyte,HEX2 DatenRX.lowbyte,13]
    Pause 2000
    Command = 0
    Goto Main
    Regards Pesticida
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Any Ideas for a cheap touch sensor??????
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 19th October 2013, 01:33
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. LED Touch Sensor
    By ngeronikolos in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 02:15
  5. Replies: 6
    Last Post: - 18th January 2008, 09:17
