EDIT: Here is all you need right here - a fully explained pic metal detecter with hex file!!
http://geotech.thunting.com/cgi-bin/...art2/index.dat
Originally Posted by
G-R-C
Thanks for the links Locko. Some of these I have seen before.
I too was thinking about the BFO detector as well. However
you are first person I have had any conversation with who has some real
feedback on the subject. Seems intersting that your's is only able
to read into the ground just a few inches.
See below
The circuit with PIC is very cool. This looks like a good place to start.
I'd like to write my own code. Maybe it would be possible to block
certain metals like aluminum and iron from being detected.
This way somebody doesn't keep digging up trash.
Yes you can, it has to do with the return signal. A metal near the magnetic field will affect the frequency of the search coil (Phase shift). On the BFO I made, a copper coin would increase the tone but my gold ring would decrease the tone.
Some good info here: http://www.gi.alaska.edu/~jesse/trea...wdetector.html
Any idea why yours only has a few inches of depth detection?
There are lots of things that affect the depth, voltage in the coil, size of coil, the sensitivity of the balance circuit. If I set the zero beat to just triggering with no metal, it can detect a single penny at 5-6 inches in air. My test circuit was using 5 volts and when I went to a real circuit with a 9 volt bat, the depth detection increased. Some metal detectors use 18 volts in their circuits - could be for more coil volts?
With the size, Joe is right, larger = deeper, but you will sacrifice the size of object you can detect.
Wonder if the pick-up coil senstivity can be increased/decreased.
I’m sure it can but I think switching to a good PI circuit would improve things greatly.
Thanks again Locko, this has been a huge step in the right direction.
Gordon
From what I have read, a pulse induction system is the way to go. Better depth but more complicated to build. Here is another site that has lots of good links:
http://geotech.thunting.com/cgi-bin/...e=projects.dat
I think it is best to start with deciding what you want to detect and go from there.
This has got my interest again, may have to start loosing more sleep to yet another project….
Sorry none of this really covers a pic chip, but I never got that far last time. I think the pic is probably the easier part od a good detector, the circuit and coil design is the complicated part.
Paul
Reason: Added web link
| PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
