Metal Detector
Results 1 to 19 of 19
Thread: Metal Detector
    Aug 2013
    Default Re: Metal Detector
    Quote Originally Posted by G-R-C View Post
    Thanks for the links Locko. Some of these I have seen before.
    I too was thinking about the BFO detector as well. However
    you are first person I have had any conversation with who has some real
    feedback on the subject. Seems intersting that your's is only able
    to read into the ground just a few inches.
    The circuit with PIC is very cool. This looks like a good place to start.
    I'd like to write my own code. Maybe it would be possible to block
    certain metals like aluminum and iron from being detected.
    This way somebody doesn't keep digging up trash.
    Any idea why yours only has a few inches of depth detection?
    Wonder if the pick-up coil senstivity can be increased/decreased.
    Thanks again Locko, this has been a huge step in the right direction.
    Gordon
    I know nothing about the BFO detector. I just heard about metal detector and gold detector.
    Apr 2011
    The single most important part of any metal detector is the coil assembly. A PIC is usally only used to make 'fancy' displays of the resultant signal but you can't make a silk purse from a sows ear - in other words, without a decent coil/detection system using a PIC won't add any additional advantages.
    Elektor magazine, November 1981, has a good (very, very good) metal detector circuit (with pcb layout etc) if you can get a back issue - my pdf of the article runs to around 8.5Mb in size.
    Jul 2006
    Another good source is the BS2 Parallax forum, where is a small design called Sensitive Metal Detectors, wiring and source code are available from there, i think is easy to experiment with, porting the code as well !
    http://forums.parallax.com/showthrea...144#post467144
    not tried yet but soon.
    Jan 2012
    Grid EN19MV
    Quote Originally Posted by kellyseye View Post
    Went hunting for this when I saw your post and found THIS. I ordered one immediately, what a great resource.
    -Stephen Hawking
  1. Replies: 6
    Last Post: - 10th September 2008, 11:04
  2. Replies: 10
    Last Post: - 16th October 2006, 19:23
  3. IR detector
    By geckogrotto in forum mel PIC BASIC Pro
    Last Post: - 30th August 2006, 04:16
  4. Replies: 4
    Last Post: - 20th September 2005, 16:27
  5. Inductive Loop Detector
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 18th October 2004, 10:45
