Lcd With 16f819
Results 1 to 7 of 7
Thread: Lcd With 16f819
    some thing like this I think and your on the wrong forum
    DC_Loops = 20
    ADC_Channel = 1 ' ADC on first reference
    GoSub ADC_Average ' Perform an averaging to enhance accuracy
    Temp_Float = ADC_Result ' Store the result
    ADC_Channel = 0 ' ADC on second reference
    ADC_Result = ADC_Result * 5000 / 1023 ' Convert values into Volts (with a scale of 1000)
    Temp_Float = Temp_Float * 5000 / 1023 ' to reduce decimal error
    ADC_Result = ADC_Result - Temp_Float ' And calculate difference
    ADC_Result = ADC_Result / 10 ' Scale back down remembering 10mV = 1 Deg C
    If ADC_Result <> Last_Result1 Then ' Check if the data has changed
    Print At 1,1, DEC1 ADC_Result, 0, "C " ' and only update display if it has
    Last_Result1 = ADC_Result ' Store new data
    EndIf
    GoTo Main ' Loop for ever
    ADC_Average: ' Perform an averaging on ADC conversions
    ' to reduce errors
    ADC_Total = 0 ' Clear summing register
    For Temp = 1 To ADC_Loops ' Loop for a pre-determined number of times
    ADC_Result = ADIn ADC_Channel ' Grab a new ADC value
    ADC_Total = ADC_Total + ADC_Result ' Sum it to the total register
    DelayUS 1 ' Allow internal capacitors to discharge
    Next Temp
    ADC_Result = ADC_Total / ADC_Loops ' Determin the average of all the equations
    wilfrieds's Avatar
    wilfrieds Guest
    Default adc stabilized
    Hi guys
    thanks for the tips.
    The adc jumping was sorted out by putting the cap closer to the 7805 regulator.
    A Tantalium cap also improved stability. so for good measure I ised both.
    I also tried ceramic caps but they didn't make any difference.
    The ADC range adjustments seem interesting, still working and experimenting with that one.
    Math calc's don't always seem to be spot on.??? ( maybe it's back to school).
    Wilfried
    wilfrieds's Avatar
    wilfrieds Guest
    Default adc display
    One more problem remaining.
    How to display say 4.85V from a ADC result.
    Problem being the dot off course.
    Wilfried
    As your as your result = 485 or 4850, you just need to format it. Look for DIG and DEC modifier in the LCDOUT section.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
