cable tv addressable box
Results 1 to 15 of 15
    Sayzer taught me how to set up and implement timers . . . Free, and then opportunity came along and I taught someone else what Sayzer taught me, So on their, and my behalf, Thank You Sayzer !
    Quote Originally Posted by tishri
    and how could i merge the signal from PIC to cable TV signal
    A coax relay.
    Expensive though, about $100 each.
    Could anyone enlighten on the use of a DiSEqC switch for analog or digital TV coax switching?
    "Ricks Satellite"
    Norm
    What are the components of a DiSEqC switch?
    Norm
    Hangover, Germany
    Red face
    A coax relay.
    No,
    a coax relais may switch between to cables, he needs a modulator to put his information on the cable.
    Red face brings back memories.
    this is just about exactly the way cable companies did it with their old analog boxes. they had a digital control signal between channels that addressed a box and told it what channels to descramble. a friend of mine *cough* used to have a test box that blocked the control frequency [this case was 107mhz i think, selectable via dip switches for that box brand or cable carrier] and sent its own signal to the box. it would go through each address and activate all channels. eventually it would get to the address of the box connected, sometimes it took a few minutes. if i remember correctly it was a pic sending the codes.
    Jan 2006
    Istanbul
    Words are not enough to express what I feel now.
    Keep sharing the knowledge we have.
    Thanks very much Joe.
    Sep 2007
    Default thank u
    currently guys, here in the Philippines, most of the cable company uses analog signals.. is there a best way to use this technology(analog) from unauthorized use.
    I am thinking of addressable taps or addressable box. hahahah
    thanks a lot for sharing.. im still gathering information so I can have the idea where to start.
  1. 'POT' issues with long cable
    By ardhuru in forum General
    Last Post: - 22nd July 2009, 01:21
  2. DS1820 Max Cable length ?
    By dccch in forum General
    Last Post: - 24th January 2008, 07:44
  3. Maximun Cable Length for PIC to LCD
    By wildbilly in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 19:00
  4. Outdoor box
    Last Post: - 1st December 2007, 10:53
  5. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 18:45
