Using Cheap Chinese Calipers as encoders
Results 1 to 13 of 13
    Exclamation 5 ipm is a W. A. G. 1 ipm is adequate, even less
    Actually rethinking this whole thread, 5 ipm is pretty fast for the size constraints these calipers offer, What I have in mind is to make a small engraving machine for semi precious stones, like turquois, I am presently in process of purchasing a HAAS TM1 from a friend, so my short term CNC needs will be filled by that, the stone cutter is to be for My Mom. I was toying with the Idea of tracking the Z axis of a larger machine though.<p>
    Speed isn't going to be the issue. My problem is how do I retreive the data from a 48 Bit data stream with a 16 bit word capable Microcontroller, I am guessing it can be done as at least 3 comercial enterprises use them as the basis of a DRO, my math skills and inadequate experience in programming are such that I am looking for suggestions as to how to accomplish this feat, mind you, not a code author, but some pointers. Would you store it in 3 words ? Would that involve using an array, something like:<p> MyData var word[3]<p>
    Thank You All for your time and consideration, it is appreciated.
    JS
    Sep 2007
    USA, CA
    MyData var word[24]<p>
    The PIC only handles 8 bits--your limitation of 16 is within the compiler, which you can always try another. If you want to stay with the existing one, then the array is probably the best way to go. You'll just have to work out any math commands that you want.
    Aug 2005
    I have read the 52 bits of data out of a Mitutoyo dial indicator with a pic.The clock signal is tied to an interrupt pin and the data is read into a 52 bit array.The data can then be manipulated however necessary.The Chinese calipers while different, can probably read in a similar manner.
    Thanks arniepj,
    So if I got this right, output the clock and data pins through a couple of comparators or OPAmps, to get levels up to 5 volt levels, and hook the clock pin to an interrupt on change pin then read the data into array, sounds simple enough, I have to read up on getting the data out of an array, in a way I can use and understand it.
    JS
    Aug 2005
    I used a 16F877 with the data tied directly to portb.1 and the clock tied directly to portb.0.Enabling the weak pull up resistors was all that was needed.I believe the signal voltage levels were on par with the caliper levels.Looking at the link waveforms,I would start by capturing the pause in between the clock pulse groups as an indicator to start clocking the data.
    Thank You.
  1. Quick thoughts: DT Ints with encoders
    Last Post: - 7th January 2010, 01:01
  2. quad encoders
    Last Post: - 13th March 2007, 17:49
  3. Chinese Calipers
    By anj in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 08:13
