18F4550 compiles, 18F4620 does not
Results 1 to 3 of 3
    Default 18F4550 compiles, 18F4620 does not
    The following trivial code compiles if I select 18F4550 via the MCS+ 3.0.0.0 drop down box.
    I have tried PBPL ver 2.50 and PBPW ver 2.47.
    If I select the 18F4620 I get
    Error [115] c:\pbp247\pbppi18.lib 1529 : Duplicate label ("DEBUG" or redefining symbol that cannot be redefined)
    There are almost identical messages with PBPW and PBPL. Only the c:\...... varies.
    Anyone got any ideas?
    Cheers
    Brian
    ''* Name : Test 18F4620.PBP *
    ''* Author : Brian Taylor *
    ''* Notice : Copyright (c) 2007 Brian Taylor *
    ''* : All Rights Reserved *
    ''* Date : 18 SEP 2007 *
    ''* Version : 4.00 *
    ''* Notes : *
    '' ************************ Defines *****************************
    DEFINE osc 4 '
    DEFINE Loader_Used 1
    DEFINE DEBUG_REG PORTC 'Debug pin port
    DEFINE DEBUG_BIT 6 'Debug pin bit
    DEFINE DEBUG_BAUD 19200 'Debug baud rate
    DEFINE DEBUG_MODE 0 'Debug mode: 0 = True, 1 = Inverted
    A var byte
    B var byte
    ShowRevStatus: ' zzzzz remove in runtime version
    pause 50
    debug $0D, $0A
    for a = 2 to 42
    read a,b
    debug b
    next a
    debug $0D, $0A
    Open and edit the Microchip header file P18F4620.INC. Comment out DEBUG, and save the
    file. That will get rid of the error.
    LVDCON EQU H'0FD2'
    OSCCON EQU H'0FD3'
    ; DEBUG EQU H'0FD4' ; <--- comment this out & save
    T0CON EQU H'0FD5'
    TMR0L EQU H'0FD6'
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default DEBUG problem with 18F4620
    Thank you Bruce and Jeff Schmoyer.
    Thank you Jeff for the prompt personal reply.
    Bruce's comment above is exactly right and does fix the problem. I must say I usually regard the xxx.inc files as sacred and not to be messed with by amateurs like me.
    This is what I did.
    I went to c:\mpasm\p18f4620.inc and saved a copy.
    I opened c:\mpasm\p18f4620.inc and a couple of pages into the file, at the first instance of the word "DEBUG" I commented out the line with a semi-colon.
    OSCCON EQU H'0FD3'
    ; DEBUG EQU H'0FD4'
    T0CON EQU H'0FD5'
    Cheers
    Brian
  1. 18f4550 usb problem.. so im getting crazy..
    By MeSaKu in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 22:03
  2. Usb Mass Storage With 18f4550
    By wagner in forum USB
    Last Post: - 17th August 2008, 16:46
  3. 18F4550 to 18F2550
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 28th September 2007, 23:13
  4. How can I turn off USB support in 18F4550
    Last Post: - 6th September 2007, 03:56
  5. USB Programmer for 18F4550 PICs
    By Kamikaze47 in forum USB
    Last Post: - 21st August 2007, 16:29
