npn reflective photo sensor input
Results 1 to 9 of 9
    Quote Originally Posted by BrianT View Post
    Hi darrel,
    I don't think that is it.
    Oh, I agree with your other post for the "IT".
    Unless it's a pre-biased transitor, as soon as it trys to engage the relay, it's going to reset the PIC.
    Was just trying to add some more.
    And after looking a little further, I'd say, leave the sensor like it is, But add a 10K resitor from the N.O. output to gnd.
    That would still give the voltage divider, and some protection against incorrect wiring.
    I know you can clamp things with the diodes, I see it used all the time for RS232 etc.
    Just a personal thing I guess. I try to keep the inputs between 0-5V at all times.
    Sep 2005
    Default Thanks for the help
    Thanks to everyone for the help. I am not sure why, but moving the 10K to ground does not work.
    With the 10K to the input the circuit works, but it is inconsistant which I think may be due to noise.
    Hi Armadus,
    If I read the schematic correctly, from the data sheet, this PIR is supposed to sink the current when switched on, and so should be connected to the pic pin directly. As it is wired, it wil merely reduce the voltage to the calculated divider voltage, roughly 1/5 of the 24v supply, the rest of the time the pin will be somewhere between that value and 24v depending upon how much current the pic is sinking through the resistors.
    JS
    Armadus, The sensor is an open collector device. Just provide a pullup resistor of about 4.7k to +5 volts and you are good to go......
  1. Reading A Photo Resistor using ADC
    Last Post: - 25th January 2007, 10:28
  2. Replies: 5
    Last Post: - 2nd March 2006, 10:21
