x10 - europe FYI
Results 1 to 13 of 13
    Sep 2007
    Are you trying to build your own PIC-based X-10 interface to the power line? If so, there are some people here who have done that who might be willing to share if you can provide details such as power line voltage and frequency.
    Yes, I want to do this, would you please give me one?
    I appreciate your replies and your interests
    Dec 2005
    You still haven't provided any details so I don't know whether you are dealing with 120VAC/60Hz or 230VAC/50Hz mains.
    Here are URLs to several datasheets, application notes, and schematics of some X-10 PLC interfaces. They show various techniques for coupling to the powerline. While some are for FSK and/or obsolete parts, the powerline interface details still apply to X-10 and ASK modulation.Anand Dhuru, who posts here, has designed PIC-based X-10 interfaces and may be willing to share details.
    Thanks, Dave.
    Yes, I can indeed give pointers in this area.
    The PL513 is a transmit-only interface. The reason the schematic looks somewhat complex is, first, it has optos to isolate the controller from the mains, and secondly, it generates its own 120 khz modulatoin so that you dont have to.
    I, with Darrel's help managed to modify the .lib file so that the XOUT signal on a pin comes out pre-modulated at 120 khz. Now, its a simple matter of coupling it to the mains. For this, I used a simple transformer used in AM radios (the one with a white slug).
    I'm sorry I dont have a part number for the transformer; Dave with his experience in RF could perhaps specify one.
    If you go the route I did (minus the optos) be *very* careful with safety aspects. My controller was completely self contained (including the pic), and so I could afford a tranformerless-opto-less design.
    This circuit from Nuts'N'Volts would perhaps help.
    Anand
    Digikey (among others) seem to stock this part.
    http://parts.digikey.com/1/parts/666...vxa042yuk.html
    Anand
    Dec 2005
    I meant to mention the Nuts & Volts article but couldn't find my notes on it.
    This is the three winding transformer used by X-10.
    http://aeneas.com.cn/PDF/SUMIDA/GENE...nformation.htm
    Sep 2007
    Thanks, Dave.
    Anand
    Would you please give me the date of article for x10 which published at nuts and volts?
  1. X10 commands and PBP
    By aratti in forum mel PIC BASIC Pro
    Last Post: - 15th November 2009, 12:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
  3. help with fan controller X10
    By iova in forum General
    Last Post: - 11th August 2006, 00:37
  4. FYI Daylight Saving Time in the U.S.
    By ccsparky in forum General
    Last Post: - 7th November 2005, 15:05
  5. Xin & Xout Europe (50hz) vs US (60hz)
    Last Post: - 2nd May 2005, 11:49
