IR Sensors
Results 1 to 13 of 13
Thread: IR Sensors
    Aug 2005
    down south
    from my dealings using PIR 's they are very unstable with out the lens
    do a search on the web they make a lot of lens wide angel, long range etc.
    and diffrent focul lenghts.
    Thank you very much Grounded!!
    Grounded
    According to the electronics123 catalog the "PIR Movement Detector Module" (KC7783) has a fresnel lens already integrated.
    Here is a piece of their description:
    "A pyroelectric sensor module which is developed for human body detection. A PIR detector with a fresnel lens are mounted on a compact PCB tohether with an analog IC...."
    The detection range is 3 meters, do you think this module will be reliable if I connect it to a pic without any additional fresnel lenses?
    Thank you koossa
    Aug 2005
    down south
    Smile
    yes it does. what testing I did with the factory lens it work fine but did not have the distance I need the little lens just pops off and I set it up with a new lens and I get 20 yards. I think they are used by a of lot robot builders you mite check some of there forums. the range they use is more like what you need.
    if I can help let me know
    grounded
    Thank you!!
    Sep 2007
    Default IR Sensors
    If you are planning to use a PIR sensor outdoors, be aware that they tend to
    pick up *ANYTHING* moving. I have a neighbor with PIR-activated spotlights
    and the things go on every time a field mouse sneezes or a bug flys past and
    momentarily blocks some more distant heat source.
    PIRs respond to a *change* in temperature, take one of the little plastic lenses,
    bend it like in the unit and move past a light source. You'll see that they're
    designed to create a parade of little images that slide past the sensor. A moving
    object will cause a hot spot to reach the sensor, then there's a null, and then
    the next image comes by. The 'sensitivity' setting on some sensors generally
    sets how many times the hot spot has to come by in a given time to trigger the
    device.
    The best way to get around the "Sees everything" problem is to use two or
    more sensors set to have somewhat overlapping fields of vision in the zone
    you're interested in. Hook the outputs up "AND"-style, so both sensors must
    be activated at the same time before you register a positive hit. Likely, a
    mouse or whatever will be in view of one sensor but not another. Aiming them
    at slightly different heights - say 3 feet and 5 feet - is also useful since all
    but midgets will trigger both, but a dog or cat or mouse won't be tall enough
    to trigger the 'high' sensor.
    An alternative to PIRs or straight thermopiles is to use an IR "distance sensor".
    Sharp makes a lot of these, and they're pretty cheap and straightforward. If
    you've ever been in a public restroom with the automatic urinals and sinks,
    this is what they're using. They work on 'triangulation' - an IR beam goes
    straight out and then the reflection hits a photodiode strip behind the receiver
    lens. Close objects illuminate just the cells at the edge of the strip wheras a
    more distant object is fully "in the picture" and illuminates more. Max range
    last time I checked was about four feet - and I've got part of a PBP program
    for reading them. In theory an external lens can extend the range somewhat
    at the expense of accuracy.
    They ARE pretty accurate too, about 1/10th of an inch through most of the
    operational range. Won't work if the optics get fogged-up though. Got 'em
    from some robot-supply company. Some models supply a 0-3vdc output
    you can use with any PIC with an A/D converter. Others source current.
    I don't recall if any output a frequency-changing pulse or not.
    http://www.mouser.com/search/Product...2-GP2Y0A02YK0F
    http://document.sharpsma.com/files/gp2y0a02yk_e.pdf
    A related cheap way to sense someones approach is to buy one of those
    "ultrasonic rulers" from the hardware store and wire into it in some way.
    I've seen some for $19.95 and they sport a range of 12 to as much as
    25 feet. HOW to hook 'em up would depend on the exact model and
    what kind of info you want from it. They're a fairly narrow beam, so
    interference from nature is reduced. Alas, a hard rain might reflect
    back enough of the ultrasound beam to create false data. Thermal
    sensors aren't so easily fooled by rain.
    -Jimbo
    Wink
    Thank you Jimbo!!!!
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. How to work with IR sensors
    By The Master in forum General
    Last Post: - 23rd December 2007, 15:40
  3. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 12:40
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 18:12
