IR Sensors
Results 1 to 13 of 13
Thread: IR Sensors
    Default IR sensors
    You talk of a "motion sensor". Do you mean a human presence/absence detector or a velocity measurement system.
    If you are looking for humans, the easiest is to buy two ready to go PIR (Passive Infra Red) sensors. These are $10 and up and give a saturating transistor as the output. Harder to use, but more versatile, are the $30 thermopiles from companies like Melexis (which I use). Thermopiles can measure temperature remotely while the PIR style just detect a thermal anomaly and turn on the output transistor.
    The thermopile approach requires you to build a reasonably sophisticated high impedance, very low leakage op amp circuit.
    Tell me more about what you are trying to do and I can explain further.
    HTH
    Brian
    Hi Brian
    Thank you very much for your feedback!
    Yes, I am talking about human presence/absence detector.
    I just need something that will be reliable and it's for outdoor purposes (for security).
    Do I need 2 sensors, or will one be reliable enough?
    Thx a lot!!
    koossa
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. How to work with IR sensors
    By The Master in forum General
    Last Post: - 23rd December 2007, 15:40
  3. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 12:40
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 18:12
