Help me to invert voltage
Results 1 to 3 of 3
Threaded View
    Sep 2007
    Default Help me to invert voltage
    Hello, it is my first post.
    I want to modify simple voltage divider to have 2 simultanous outputs:
    a) output 0 to 5v
    b) output 5 to 0v
    example : if the output a is 1v then output b is 4v, if output a is 2.5v , output b is 2.5v
      5v----
            I
            >  pot 10k
            <----------> output  a (0 to 5v)
            >       I
            I       I
      gnd---        -------- ?????? -------> output b (5 to 0v)
    can opamp be used as inverted voltage follower ?
    thank you
  1. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 11:50
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 20:32
  3. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 19:20
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  5. Low Voltage Detection
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 18:29
