Tristated output to two common Base transistor issue
Results 1 to 40 of 55
Threaded View
    SWITZERLAND (french speaking)
    Default Tristated output to two common Base transistor issue
    Hello,
    I have to power automotive LEDs that drain 50mA.
    I use twenty LEDS and have a 16F630, so my circuit connects two LEDs to 1 I/O port and I use the Z state to switch them OFF.
    To make this without destroying the PIC, I use transistors like this (one port example):
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1965&stc=1&d=118901631 5">
    Problem: when I have set the port direction to Input (=Z state), both LEDs still light; less than normal, but still enough to make this look not good.
    The SMD transistors have built-in 22k resistors like this (the PNP one has same connections):
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1964&stc=1&d=118901608 9">
    I tried to add 1k resistors at each Tr's Base, but... still the same.
    Is there a way to sort out this issue?
    NB: how do I put text beside the images???
    Roger
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
