using the pwm's in pic18f2431-2331-4331-4431
Results 1 to 28 of 28
    If you're using HPWM you don't need to mess with Timer2. It's automatically handled
    for you.
    If you plan to setup hardware PWM manually, these calcs should help.
    PR2=(Fosc/(4*PS*Freq))-1
    TMR2 Prescaler = 1 PR2 = (8MHz/(4*1*12,000)) = (8MHz/48,000)-1 PR2 = 165.666
    TMR2 Prescaler = 4 PR2 = (8MHz/(4*4*12,000)) = (8MHz/192,000)-1 PR2 = 40.666
    TMR2 Prescaler = 16 PR2 = (8MHz/(4*16*12,000))-1 = (8MHz/768,000))-1 PR2 = 9.416
    CCPR1L:CCP1CON<5:4>=(PR2+1)*4*Duty%
    (165+1)*4*0.5 = 332
    (40+1)*4*0.5 = 82
    (9+1)*4*0.5 = 20
    To load the duty cycle registers just place the value calculated in a word, and
    do something like this;
    Duty = 332              ' Roughly 50% duty cycle
    CCP1CON.4 = Duty.0	' Setup 10-bit duty cycle as
    CCP1CON.5 = Duty.1	' a 10-bit word
    CCPR1L = Duty >> 2
    Search here for HPWM and you'll find a boat-load more examples.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2010
    Hi Bruce,
    you mentioned above that the equation used to calculate the PWM resolution is
    log(20MHz/19.455kHz) 3.01
    Resolution = ------------------ = ----------- = 10 bits
    .301 .301
    In the 18F2431 datasheet it says that Fosc must be divided by four, i.e.
    log(5MHz/19.455kHz) 2.41
    Resolution = ------------------ = ----------- = 8 bits
    .301 .301
    and in other microchip document (link below) it provides the same equation you used.
    http://ww1.microchip.com/downloads/e...doc/31014a.pdf
    I am confused here! Can you please tell me what you think of that?
    Kind regards,
    Look at equation 17-4 PWM RESOLUTION. Then look at Table 17-2 just below it.
    Try plugging in some numbers on your calculator using both methods, and see what you get according to the resolutions shown in Table 17-2 for different values of Fosc, at various frequencies.
    -Bruce
    tech at rentron.com
    Jan 2010
    You are right. So for 10 bits, thats 2 LSBs of PDCxH and 8 bits of PDCxL. Thanks.
    PDCxH gets the 2 MSBs. PDCxL the lower 8-bits.
    -Bruce
    tech at rentron.com
    Mar 2014
    Default Re: using the pwm's in pic18f2431-2331-4331-4431
    hello bruce
    i have a doubt abt carrier generation in 18f4431.sine wave ne how il generate through luk up table bt m nt bin able to generate carrier frequency of 20khz to compare it with ma sine wave.i'm attaching image for ur reference.can u plz help me in dis .Name:  carrier vs reference plot.JPG
    Jan 2013
    Finding this old thread may have answered some questions, I wanted to know, so thanks for it, especially Bruce.
    Cheers, Camerart.
