How to use Internal Oscillator?
Results 1 to 5 of 5
    Jul 2007
    Default How to use Internal Oscillator?
    This is my config now
    @   device  pic16F648A, hs_osc, wdt_off, mclr_on, lvp_off, protect_off
    Is it only to change "hs_osc" to "xt_osc" to use the Internal Oscillator?
    Or how should I do?
    @   device  pic16F648A, xt_osc, wdt_off, mclr_on, lvp_off, protect_off
    Perth, Australia
    which assembler are you using? MPASM?
    I know how to do it for MPASM, which is to change ur config to:
    __config _INTOSC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    u could try this if you dont use MPASM (but i'm not 100%):
    @ device pic16F648A, intosc_osc_noclkout, wdt_off, mclr_on, lvp_off, protect_off
    Jul 2007
    MPSAM..?
    Hi xobx,
    Microcode studio uses an assembler called PM by default. Mpasm is the assembler used by Microchip. The config listed below is for PM.
    @ DEVICE pic16F648, INTRC_OSC_NOCLKOUT, wdt_off, mclr_on, lvp_off, protect_off
    <p>
    See the link listed below for some fine samples, courtesy of Melanie.
    http://www.picbasic.co.uk/forum/showthread.php?t=543.
    To use MAPSM as the assembler you have to tell Microcode Studio, to use it.
    Perth, Australia
    Microcode Studio is an editor - To write your code
    Picbasic Pro is a compiler - To compile your PBP code into assembly code
    MPASM is an assember - To assemble the assembly code into machine code the PIC will understand.
    You can check to see if you are using MPASM by going to the View menu in MicroCode Studio, choosing Comple and Program Options, and then clicking the Assembler tab. If Use MPASM is ticked, you are using MPASM.
    If that is the case, go to the 16F648A.INC file in your PBP directory, and change "__config _XT_OSC" to "__config _INTOSC_OSC_NOCLKOUT"
  1. Pic16f882 internal oscillator
    By offlander in forum mel PIC BASIC Pro
    Last Post: - 4th October 2009, 20:15
  2. Internal oscillator please help
    By timbash in forum mel PIC BASIC Pro
    Last Post: - 26th February 2009, 14:11
  3. PIC18F4620 Using the Internal Oscillator
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2007, 08:07
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
  5. PIC12F629 w/ Internal Oscillator
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 24th June 2004, 19:12
