Need help for PIC16C745
Results 1 to 17 of 17
    Smile Need help for PIC16C745
    Hi everybody,
    I'm using the PIC16C745 microchip to do my final year project
    the situation is, if switch 1 is pressed, LED will light up and when switch 2 is pressed again, the LED will go off. I am using an assembly language ( sofware MPLab version 7.2) to write the code. I have encounter some problem, when i apply the 5 V to the circuit. The Led must Light up, but it did not .
    Here is myCode:
    MAIN org 00000030h
    Start
    bsf STATUS,RP0 ; select bank1
    clrf PORTB ; clear PORTB output latch
    movlw b'00000110' ; Set all pins PORTB 1,2 as Input
    MOVWF TRISB ;
    ON
    btfsc PORTB,1 ; Has S2 been press? (Normally high,goes low when pressed.)
    goto ON ; No, go back check again
    movlw b'00000001' ; move it from register 1 to w.
    movwf PORTB ; move it to PORTB to light up the LED
    OFF
    btfsc PORTB,2 ; Has key been press? (Normally high, goes low when pressed.)
    goto OFF ; No, check again
    movlw b'00000000' ; move it from register 1 to w.
    movwf PORTB ; OFF the LED
    DebounceA
    btfss PORTB,1 ; Has key been released?
    goto DebounceA ; No, wait again
    goto Start ; Loop again
    end ; directive indicates end of code
    I use only one port instead to be an input and output. When i build the code inside the PIC16C745, the Led still not turn on. Can you help me to see weather to code i have done correctly. Thank you
    Hi christina86,
    Certainly I am not the one to ask about assembly language. That said, it looks to me like your sub routines get locked into a loop and never finish their execution.
    example<p>
    ON
    goto ON ; No, <font color=red> goto ON and repeats forever</font color>
    movwf PORTB ; move it to PORTB to light up the LED<p>
    I think if you wish to recheck the first line you should use whatever assembly equiv. of a for next loop.
    JS
    Feb 2003
    Salt Lake City, Utah USA
    Hi Christina86,
    This is a BASIC language forum ... ASM help is harder to get here. A quick look at your program......
    See Table 4.2 in the 16F745 datasheet. You will see that PORTB resides in BANK0 and TRISB resides in BANK1.
    When you want to work with PORTB, you need to make sure you are in BANK0 (clear RP0 and RP1 in the STATUS register)
    When you want to work with TRISB, you need to make sure you are in BANK1 (set RB0 as you did)
    If you want to continue on and change PORTB values, you need to switch back to BANK0 before updating PORTB (otherwise you will actually update TRISB even though you told the program to update PORTB)
    Start
    	clrf PORTB ; STATUS defaults to BANK0 - clear PORTB output latch  (not really a latch)
    	bsf STATUS, RP0 ; select bank1
    	MOVWF TRISB ;
    	bcf STATUS, RP0 ; go back to  Bank 0
    The 16C745 appears to be an interesting chip – I hope you are using the windowed version.
    Being that this is a BASIC forum, I should tell you that what you are trying to do would be trivial with PicBasic or PicBasic Pro
    Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    Hi Joe
          btfsc PORTB,1
    this command says "bit test file skip if clear" ... it jumps (skips) over the goto is PORTB.1 = 0
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    Exclamation
    Hey Joe,
    I should note that the last time you and I tried to help someone together, we got locked up and whipped ... we better tread carefully here
    http://www.picbasic.co.uk/forum/showthread.php?t=6783
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Hi Paul and Joe,
    Thank you so mush for replying my post. I am totally new to this PIC16C745, i have got the project from my teacher which is totaly new to me, it is nothing related to my course of study. I am in the process of learning. Please give me your guidance.
    I have made some changes to the code but it is still not working . Can you help me to check?
    The code is :
    AIN org 00000030h
    Start
    movlw b'00000110' ; Set pins PORTB 1,2 as Input
    movwf TRISB ;
    ON
    btfss PORTB,1 ; Has S1 been press? (Normally high,goes low when pressed.)
    OFF
    btfss PORTB,2 ; Has key been press? (Normally high, goes low when pressed.)
    Thank you Paul and Joe so much . I look forward to hearing from you.
    Quote Originally Posted by paul borgmeier View Post
    Hey Joe,
    Yes, We were spanked ! I think this poor kid is going to have to repeat this class, I just looked at the .lst file for a simple "Blinky" and it was 57k file size, I have just downloaded Section 29 from Microchip website.
    Christina, here is a forum from Microchip, where they speak assembly, and apparently C as well.:
    http://forum.microchip.com/tt.aspx?forumid=-2
