Help...Distance Meter
Results 1 to 11 of 11
    I have an example of using the Devantech SRF04 sonar range-finder with PBP in our
    Micro-Bot projects section here http://www.rentron.com/Micro-Bot/Sonar.htm
    Devantech makes the SRF04 schematic & source code available for folks that prefer to build
    one themselves: http://www.robot-electronics.co.uk/htm/srf1.shtml
    They have several more here: http://www.robot-electronics.co.uk/s...angers1999.htm
    The Parallax PING module linked to by mackrackit should also be pretty simple to use.
    -Bruce
    tech at rentron.com
    Aug 2007
    Hello
    Thank you very much for your help.
    sorry but how can I make distance meter without using ultrasound generator, e.g. infrared or laser or other methods.
    because the tools of ultrasound doesn't offer in my country.
    Thank you.
    With standard off-the-shelf type IR components, this isn't incredibly precise, but here's
    one way to do it: http://www.rentron.com/PicBasic/infr..._detection.htm
    If you want something pre-manufactured, and a bit more accurate, then do a Google search
    for Sharp GP2D12. I've never used on myself, but I hear they're fairly accurate.
    Laser range-finders are a great deal more complex + expensive, but still an option if you have
    the budget. Here's an intro http://www.repairfaq.org/sam/lr/
    You can find a LOT more with a quick search at Google.
    -Bruce
    tech at rentron.com
    Aug 2007
    Hello
    Thank you very much Bruce ...
    Quote Originally Posted by tohu thomson View Post
    Hello
    Thank you.
    You could use a wheel and an encoder.
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 21:42
  2. Long distance Communicating between PICs
    Last Post: - 4th January 2008, 07:47
  3. Help measuring distance....
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 30th July 2007, 17:11
  4. Distance Measurement Chips
    By sayzer in forum Off Topic
    Last Post: - 2nd February 2007, 21:57
  5. GPS waypoint distance in Km
    By Art in forum Code Examples
    Last Post: - 28th August 2005, 02:59
