Make me some code..
Results 1 to 40 of 41
    Oct 2006
    Edmonton AB Canada
    So that's it? Besides the fact that significant modification, if not outright destruction would be required to get the money out of Melanie, it was an interesting discussion.
    Perth, Australia
    My solution wasn't "significant modification"... It was 1 cut of 1 wire
    Feb 2003
    Quote Originally Posted by Kamikaze47 View Post
    Hmmmmm.... sounds like a quote from a bomb disposal technician
    However, cutting one wire changes the circuit diagram so no money for you.!!!
    PS. If you are a bomb disposal technician you might want to change your name to instill more confidence LOL
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Perth, Australia
    I wasnt saying it met the "contest" criteria, I was just pointing out that it didnt require "significant modification".
    T.Jackson's Avatar
    T.Jackson Guest
    Smile New Game (AUS $25)
    New game - I'll pay AUS $25 to the person who can come up with the best DC to DC converter design. It should be low in cost, capable of producing at least 10mA @7V (~70mW of power) from a 5V source. Additional, desirable criteria in the design would include: compactness, protection, low component count, efficient, testable & robust.
    <b>The Contest</b>
    <ul>
    <li> Submit in this thread, a workable, readable circuit diagram</li>
    <li> It must be your own original work</li>
    <li> You may submit ONE design only (no amendments allowed)</li>
    <li> The design can't use a µcontroller or discrete ICs</li>
    <li> A detailed description on how your design works would be beneficial</li>
    <li> All entries must be submitted by the 31st of October</li>
    <li> The Winner will be announced in early November </li>
    </ul>
    Oh! - and feedback from people on the entries will be highly regarded, and also possibly used in helping to identify the winner, so don't hold back!
    Trent Jackson
    Default Already done?
    Have a look at
    http://www.romanblack.com/
    Cheers
    Brian
    What in software would create a collapsing field? if there was a relay coil across that led It can light.. not STAY lit, but light..
    Mar 2006
    Hyderabad (India)
    <b>The Contest</b>
    <ul>
    </ul>
    Trent Jackson
    Most probably one could sell his or her own design at much higher cost than surrender for a Aus $20/-.
    Sarma
    <b>The Contest</b>
    <ul>
    </ul>
    Trent Jackson
    Hi, trent
    Just use your OSC output to drive a common 1 transistor voltage doubler ... ( just need 1 NPN, 1 PNP, 3 resistor, 2 diodes, 2 capacitors )
    PS : 25 $ for that ... ??? where did you learn electronics ????????????????????????????????
    mpfff, there's a load of missing informations to base something like a design around the previous requirement.
    Regulated or not?
    isolated or not?
    Protection??? which?
    Expected Output voltage?
    etc etc etc.
    25$ I don't think i can do something really reliable in less than 15 minutes.. or i'll lost money... as if i really need to lost anymore now
    Maybe i should read the whole post again ?
    T.Jackson's Avatar
    T.Jackson Guest
    Hi, trent
    Thank you for your contribution, Alain. Some supporting documentation on your acclaimed working circuit would further improve your chances of winning.
    Trent Jackson
  1. Code doesn't work on 16F648A
    By Mr_Joe in forum mel PIC BASIC Pro
    Last Post: - 1st September 2018, 22:09
  2. I2C Master/Slave 16F88/16F767 working code
  3. HARDWARE I2C SAMPLE CODE question
  4. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  5. Can someone help me make a code for this:
    By joseph in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 22:03
