Using A Ds18s20 And Servo
Results 1 to 5 of 5
    Default real time servos with slow sensors
    I have some code that refreshes servos at 50 Hz and reads some DS1620 slow temperature sensors - they take 400 - 1000 mSecs about the same as the DS1820 I think. I do it with a loopcounter and issue the conversion request in one pass then 1000 mSecs later read the result. SOmething like
    MainLoop:
    LoopCtr + 1
    if LoopCtr > 50 then loopCtr = 0
    if LoopCtr = 1 then TempConversion
    if LoopCtr = 0 then ReadTemperature
    ServoCodeHere:
    Low ServoPin
    Pulsout ServoPin, ServoWidth
    Delay to give 20 mSec looptime
    Goto MainLoop
    TempConversion:
    Issue code to start the temperature conversion - don't wait for result
    Goto MainLoop
    ReadTemperature:
    Issue code to read most recent temperature conversion
    Goto MainLoop
    HTH
    Brian
    Nov 2006
    Melbourne, Australia
    Thanks Brian your code idea works a treat. So how come yours does and mine doesn't????? I just don't understand why not. The only issue now i have is the servo keeps resetting itself(matter of speach) goes in the direction i want holds for a second then rotates all the way back then rotates back to where it should be. I require the servo to stay put how do i go about this as my code does not do this when in my head it should. what am i doing wrong
    the code..
    OSCCON = %01101000 'INTRC = 4 MHz
    TRISA = %11111111
    ANSEL = 0  'DISABLE ALL ADC
    CMCON = 7 'DISABLE ALL ANALOG COMPARATOR
    WHILE OSCCON.2=0:WEND 'STABILISE THE CLOCK
    ADCON1 = 1
    PAUSE 1000
    DEFINE LCD_DREG         PORTB
    DEFINE LCD_DBIT         4 '4,5,6,7
    DEFINE LCD_RSREG        PORTB
    DEFINE LCD_RSBIT        3
    DEFINE LCD_EREG         PORTB
    DEFINE LCD_EBIT         2
    DEFINE LCD_BITS         4
    DEFINE LCD_LINES        2
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS       50
    lcdout $fe, 1
    ServoWidth var byte
    ServoPin Var PORTB.0
    ServoWidth = 1500
    DQ	VAR	PORTA.1			' One-wire data pin
    b3 var byte
    b3 = 1200
    temperature VAR	WORD			' Temperature storage
    count_remain VAR BYTE			' Count remaining
    count_per_c VAR	BYTE			' Count per degree C
    TEMP VAR WORD
    LoopCtr var byte
    MainLoop:
    LoopCtr = LoopCtr + 1
    IF TEMP > 24 THEN ServoWidth = ServoWidth - 1
    IF TEMP < 22 THEN ServoWidth = ServoWidth + 1
    if TEMP = 23 THEN ServoWidth = ServoWidth + 0
    ServoCodeHere:
    Low ServoPin
    if ServoWidth = 1105 then high ServoPin ' servo stop
    if ServoWidth = 1895 then high ServoPin ' servo stop
    'Delay to give 20 mSec looptime
    PAUSE 18
    Goto MainLoop
    TempConversion:
    'Issue code to start the temperature conversion - don't wait for result
     OWOut DQ, 1, [$CC, $44]       ' Start temperature conversion
    Goto MainLoop
    ReadTemperature:
    'Issue code to read most recent temperature conversion
    DS18S20WAITLOOP: OWIn DQ, 4, [count_remain]	' Check for still busy converting
    	IF count_remain = 0 Then DS18S20WAITLOOP
    OWOut DQ, 1, [$CC, $BE]		' Read the temperature
            OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
            temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    TEMP = temperature / 100
        LCDOut $fe, 1, DEC (temperature / 100)," C"
    Goto MainLoop
    Crazy Cooter
    IF ITS STOCK IT WONT ROCK
