Allegro A6280 with PICBASIC
Results 1 to 26 of 26
    I don't know why it wouldn't, except maybe for the PAUSEs.
    The last code posted would take over 42 minutes to dim from 1023 to 0 with the included pauses.
    Can you post your code again the way it is now?
    Aug 2007
    Red face
    BVar = 1023
    blue:
    shiftout d2pin, c2pin,1 [funct\1,Rvar\10,Gvar\10,Bvar\10]
    gosub latch
    gosub BringUpPWM
    Bvar = Bvar - 2
    if bvar < 3 then goto end
    gosub blue
    I was expecting gradual dimming of the LED, but it pulsates and intensity seems the same.
    END is a reserved word and can't be used as a label.
    The blue loop is GOSUBing back to itself. It should be GOTO.
    And, it needs to turn off the CCP module before shifting any data.
    Make sure the PAUSE 500 is NOT in the latching: subroutine anymore.
    BVar = 1023
    blue:
        CCP1CON = 0
        gosub latch
        gosub BringUpPWM
        Bvar = Bvar - 2
        if bvar < 3 then goto BlueDone
    GOTO blue
    BlueDone:
    Aug 2007
    Ok, I'll try the code tomorrow morning as it is too late now. Hope it works, thanks and I'll let you know the result by tomorrow. Thanks
    Aug 2007
    Thumbs up
    BINGO! Darrel, you're the best! Thank you again for the code, now I can dim the LED. Now, the only think in my concern is that when I control too many clusters, the PIC might not be able to store that much of data isn't it? Do you have any recommendation? Hehehe, sorry if I ask too much but really appreciate your help. God bless. Thanks again.
    Awesome!
    Not bad for someone that's never seen that chip before. eh
    Well, as far as the memory requirements go. At 6 bytes per cluster (PWM only), you can run an awful lot of clusters with just about any chip. But if it gets to be too many, just throw on a serial FRAM, and you could light up several hundred or thousand clusters, easily.
    Well, assuming you had that may pins on your PIC.
    Since each cluster needs it's own Latch line, it's kind of limiting.
    Of course you could always run the devices in series with a common latch, or add some shift registers to increase the Latch count, but now I'm getting into a whole different area.
    Aug 2007
    Default Help
    Dear Darrel, I still need some help here. Can you kindly give me your email address? I need to send some attachment to you. Thanks & have a great weekend.
    Warmest Regards,
    Kevin Loh
  1. Picbasic VS C Compiler
    Last Post: - 11th October 2005, 22:44
  2. Replies: 22
    Last Post: - 12th July 2005, 18:39
  3. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
  4. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 11:04
  5. PicBasic Pro & PicBasic syntax different
    Last Post: - 16th April 2004, 22:19
