Great! Glad you got it working.
I guess you don't "really need" to use them. You could just set the current with the REXT resistor, and use the PWM like normal. But if you want to match the brightness of the 3 LED's, then you'll need to set the DOT correction registers.Besides that, Do I really need to use the Dot Correction?
They Power-up at 36% of the REXT current setting.
So be sure you don't have too much current set-up before trying this. I don't want to blow up your LED's.
But this should set the DOT registers to full current.Then just GOSUB SetDotsCode:Rdot VAR BYTE Gdot VAR BYTE Bdot VAR BYTE Zeros VAR BYTE : Zeros = 0 Rdot = 127 ; Set these to match LED brightness (max 127) Gdot = 127 Bdot = 127 SetDots: funct = 1 CCP1CON = 0 shiftout d2pin, c2pin, 1, [funct\1,Zeros\3,Gdot\7,Zeros\3, _ Rdot\7,Zeros\3,Bdot\7] high latch @ NOP low latch CCP1CON = %00001100 funct = 0 RETURN
HTH,
