Allegro A6280 with PICBASIC
Results 1 to 26 of 26
    Aug 2007
    Default Thanks Darrel........
    Dear Darrel,
    Thanks to you. The code running well now. I can turn the color from Red to green and to blue. You are really good. Thanks again. But now, the story continue...... I need to know how to use the Dot Correction because I don't really understand the concept. Besides that, Do I really need to use the Dot Correction? Please kindly advise.
    Great! Glad you got it working.
    I guess you don't "really need" to use them. You could just set the current with the REXT resistor, and use the PWM like normal. But if you want to match the brightness of the 3 LED's, then you'll need to set the DOT correction registers.
    They Power-up at 36% of the REXT current setting.
    So be sure you don't have too much current set-up before trying this. I don't want to blow up your LED's.
    But this should set the DOT registers to full current.
    Rdot VAR BYTE
    Gdot VAR BYTE
    Bdot VAR BYTE
    Zeros VAR BYTE : Zeros = 0
    Rdot = 127  ; Set these to match LED brightness (max 127)
    Gdot = 127
    Bdot = 127
    SetDots:
        funct = 1
        CCP1CON = 0
        shiftout d2pin, c2pin, 1, [funct\1,Zeros\3,Gdot\7,Zeros\3, _
                                   Rdot\7,Zeros\3,Bdot\7]
        high latch
        @ NOP
        low latch
        CCP1CON = %00001100
        funct = 0
    Then just GOSUB SetDots
    HTH,
    Aug 2007
    Red face
    Dear Darrel, thanks for the code so I think maybe you're right. The dot correction might not playing a necessary character in here. I still have a question if you don't mind, I'm trying to dim the led by decreasing the value of bvar (let say from 1023 to 0) but no luck. May I know why? Besides that, do u have a complete set of code for this IC's controller for sale? Hope you have a good day.
    I don't know why it wouldn't, except maybe for the PAUSEs.
    The last code posted would take over 42 minutes to dim from 1023 to 0 with the included pauses.
    Can you post your code again the way it is now?
    Aug 2007
    Red face
    BVar = 1023
    blue:
    shiftout d2pin, c2pin,1 [funct\1,Rvar\10,Gvar\10,Bvar\10]
    gosub latch
    gosub BringUpPWM
    Bvar = Bvar - 2
    if bvar < 3 then goto end
    gosub blue
    I was expecting gradual dimming of the LED, but it pulsates and intensity seems the same.
    END is a reserved word and can't be used as a label.
    The blue loop is GOSUBing back to itself. It should be GOTO.
    And, it needs to turn off the CCP module before shifting any data.
    Make sure the PAUSE 500 is NOT in the latching: subroutine anymore.
    BVar = 1023
    blue:
        CCP1CON = 0
        gosub latch
        gosub BringUpPWM
        Bvar = Bvar - 2
        if bvar < 3 then goto BlueDone
    GOTO blue
    BlueDone:
    Aug 2007
    Ok, I'll try the code tomorrow morning as it is too late now. Hope it works, thanks and I'll let you know the result by tomorrow. Thanks
    Aug 2007
    Thumbs up
    BINGO! Darrel, you're the best! Thank you again for the code, now I can dim the LED. Now, the only think in my concern is that when I control too many clusters, the PIC might not be able to store that much of data isn't it? Do you have any recommendation? Hehehe, sorry if I ask too much but really appreciate your help. God bless. Thanks again.
  1. Picbasic VS C Compiler
    Last Post: - 11th October 2005, 22:44
  2. Replies: 22
    Last Post: - 12th July 2005, 18:39
  3. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
  4. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 11:04
  5. PicBasic Pro & PicBasic syntax different
    Last Post: - 16th April 2004, 22:19
