Timer Issues
Results 1 to 5 of 5
Thread: Timer Issues
    Perth, Australia
    Default Timer Issues
    Correct me if i'm wrong, but I should be able to set the value of TMR0L and TMR0H to whatever I like yes?
    If I do this as a test:
    DEFINE OSC 48
    T0CON=%10010110
    TMR0L=0
    TMR0H=0
    pause 200
    result.LowByte=TMR0L
    result.HighByte=TMR0H
    The result varies every time i do it. As if reseting TMR0L and TMR0H is doing nothing.
    However if I do this:
    DEFINE OSC 48
    T0CON=%10010110
    result1.LowByte=TMR0L
    result1.HighByte=TMR0H
    pause 200
    result2.LowByte=TMR0L
    result2.HighByte=TMR0H
    result=result2-result1
    The result is correct every time.
    Does anyone know why?
    Jan 2006
    Istanbul
    TMR0 is 8-bit.
    Which PIC is it?
    Perth, Australia
    Nope. Got TMR0 set to 16-bit.
    18F4550
    I've updated the code in the 1st post with the TMR0 settings
    Timer config is 16 bits ...
    Why not write Highbyte first ... as datasheet explains ...
    " Similarly, a write to the high byte of Timer0 must also
    take place through the TMR0H Buffer register. The high
    byte is updated with the contents of TMR0H when a
    write occurs to TMR0L. This allows all 16 bits of Timer0
    to be updated at once."
    Perth, Australia
    That did the trick.
    Thanks Acetronics.
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  3. Understanding timer issues
    Last Post: - 7th April 2009, 03:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 18th January 2009, 00:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 09:41
